clutch work, new pressure plate fingers or new pp assembly?
   / clutch work, new pressure plate fingers or new pp assembly? #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
My Kubtoa B7100d has been giving me clutch troubles lately. It does not fully dis-engage when pushing in the pedal. At real low engine speed you could shift gears but not at 'normal' engine RPM's. Clutch adjustments did not help much/for long. I suspected the release bearing based on the rumbling sound. Tractor works and sounds fine while in gear.
So I split the tractor, release bearing appears OK (will replace anyway), but the pressure plate fingers are worn pretty good.
about $12 per finger, 3 fingers for total of $36
$85 for new pressure plate assembly
I do not have a clutch alignment tool so am a little leery of taking the clutch completely apart (pressure plate fingers look like you can change them without disassembling the clutch). Anybody got any 'socket in a socket' clutch alignment tool short cuts here?
The clutch disk thickness appears OK about 1/8th inch on the pads. I have a repair manual on the way so hopefully will be able better judge tolerances after it arrives.
So should I just try to change the fingers or go the 'whole nine yards' with a new pressure plate assembly?
Thanks,
Charles
   / clutch work, new pressure plate fingers or new pp assembly? #2
While you're in that deep, I would recommend that you rebuild the clutch completely--new (or rebuilt) pressure plate, clutch disk, throwout bearing, and pilot bearing.
FWIW, a bad pilot bearing can cause the problem you describe.
As far as alignment goes, I have a tool that has various size ends to plug in the pilot bearing and has a tapered cone which slides to center the clutch disk. They're common. You can probably get one at Sears.
   / clutch work, new pressure plate fingers or new pp assembly? #3
Yes X2
   / clutch work, new pressure plate fingers or new pp assembly? #4
I have done a number of clutches over the years, but I have never
heard of separately replaceable pressure plate fingers. How does that
work?
Since the parts cost is a small part of this kind of job, I replace them all,
plus re-surface the flywheel. I don't change a flywheel unless the
starter teeth are damaged.
   / clutch work, new pressure plate fingers or new pp assembly? #5
I just did the same job on my (new to me) B7100D with 3700 hours on the clock. Had exactly the same symptoms as you!
My b7100 has a FEL and backhoe, both sub-frame mounted. Splitting the tractor involved using an angle grinder to cut parts of the subframe - it kind of cradled the bell housing! So cut and then weld to re-assemble. Building a subframe around a small tractor seems like a dumb idea to me ;-)
The pressure plate and the driven plate looked fine when I pulled it apart on first inspection, but the splines on the driven plate were WORN big time. The spigot/pilot bearing on these tractors is a bush - with a teflon lining. The pilot bearing was non-existant on my machine! The thing had long since died, the OD of the new bearing is 17mm, the hole in the back of the crank was 19.4mm :-( One of those moments when your stomach does the disappearing bit for a while...
I ended up getting a standard 20mmx14mm sintered bush and reamed the back of the crank. The motor spins at 2800rpm max, so I felt slightly happy doing the reaming by hand - I didn't want to pull the engine down too!
Now it is all back together, it runs beautifully. Alignment wasn't a biggie - the only significant problem was that the clutch alignment tool I have was too big! I think every alignment tool you'll find will be too big. The little cones that they have are too big to go through the pressure plate! I ended up using a piece of wooden dowel, with the end turned down to 14mm to fit. Like everyone else has suggested - go the whole hog and replace the bits. My pressure plate looked OK and measured up just fine, but for the money it just wasn't worth skimping.
Whole job wasn't hard/difficult or time consuming. Biggest problem was the pilot bearing and sorting out a logical solution to the gaping cavern in the back of the crank....
Cheers
/Kevin
Cheers
/Kevin
Mine has about 3850 hours so maybe that's about how long a clutch lasts? ;) Dunno if it has ever been replaced before.
I inspected things again last night and I think the clutch disk is worn more than I originally thought so it looks like I will end up doing a complete rebuild.
Mine has the backhoe and FEL as well. The subframe is a serious pain, probably doubles how much time it takes to split the tractor. I already had the backhoe off but did not want to take the FEL off as that looks like an all day job by itself. I blocked up the rear of the subframe and then took out the bolts to the rear end and the bell housing, it now supports the front end of the tractor (not sure if this is the best idea but it works). I then supported the rear half by a jack through the X of the subframe and carefully slid it back a bit at a time. Going back together is going to be much more interesting, I might need to rent an engine hoist or something to hold the rear part of the tractor for those fine adjustments.
Keeping my fingers crossed on the pilot bushing! :)
Thanks for all the input!
Charles
   / clutch work, new pressure plate fingers or new pp assembly? #7
I supported the FEL on a ladder and put the backhoe arm out. So I could move the front of the tractor. This was a mistake - the driven plate was a bit stuck on the gearbox input shaft splines - so it dragged the shaft forward and there wasn't enough clearance to get in there and grab a hold till I "wiggled" everything a bit!
The bolts holding the flywheel were a character building experience to remove - an air impact tool was ultimately used (which made it trivial). I was a bit leery about using a screwdriver to lock the flywheel by the ring gear - the aluminium castings didn't look like they'd cope with the force I was having to use to break the bolts...
If it was a simple split-n-fix, I'd rate the job as no more than 4 hours. Not hard at all - alignment just requires *grunt* !
Cheers
/Kevin
   / clutch work, new pressure plate fingers or new pp assembly? #8
work?
My last rig suddenly started grinding the gears whenever I would make a shift. I pulled the inspection plate off the side of the bell housing and each finger was held in place with a pin secured by a cotter pin. I rotated the engine checking each finger and low-and-behold one pin was half out of the pressure plate. I got a long socket-wrench extension and a hammer and was lucky enough to work the pin back in place. :D Then I got a magnet and fished the cotter pin out of the bottom of the bell housing. It was never bent over. :mad: And with the help of a set of long needle-nosed set of pliers and some rather loud cussing I was able to get the cotter-pin where it was supposed to go and bent it over so it didn't come out a second time.
Did I say that I'm a happy hydro man now? :cool: Heck with clutches, pressure plates, and throw-out bearings......
   / clutch work, new pressure plate fingers or new pp assembly? #9
Many years ago I had this penchant for drag racing. With 2 guys helping me, I could change the clutch, pressure plate and throw out bearing on a '70 Camaro in just under an hour and a half from start to backing out of the garage. Although I've never done a tractor, I'd bet I've done 50 or 60 cars and trucks. Do you know what the worst feeling in the world is when doing a clutch job? It's when the job is one of the real killer jobs that take forever and, when you are finally finished and sit in the seat to back her out of the garage and you look over in the passenger seat and see the box with the throw out bearing sitting there. :eek: :mad: That sucks!! Yeah, you know how I know that! For just a split second you think, "will it work without a throw out bearing...?"
As others have mentioned, I've never heard of changing the tines in a pressure plate. Most I've ever seen were riveted in place and I certainly wouldn't want to screw with them. Heck, one other funny thing; I was putting a clutch in a '70 Chevelle with a 454 and had the clutch bolted up to the flywheel with the alignment tool still in place. I got distracted by something and, for some reason, decided to fire up the ole hot rod to hear her run before I put the tranny and drive shaft back in. It started right up, sounded good and everything. That is when I decided to rap the engine up really hard and the metal alignment tool (an old pilot shaft from a bad tranny) dropped out in my parent's garage floor! That thing ran across the floor and went up about 7' of a drywall wall (ripping it apart on the way up). It then dropped back down to the floor and shot out the open garage door, across the street and ran off into the woods. I never found it! :eek:
Good luck, and replace the whole assembly!
   / clutch work, new pressure plate fingers or new pp assembly? #10
I agree with all here . For $ 50.00 difference. I wouldn't want to split the tractor again fror $50.00 . Replace it all while your there, That's cheeeeep insurance.
   / clutch work, new pressure plate fingers or new pp assembly? #11
Nah - my father and I (well, mostly him - I was about 12years old at the time :) ) replaced the clutch on a 1960 Vanguard (british vehicle - probably unheard of in the US). After doing the job, we couldn't find the fencing pliers - last used to twitch some wire which held the gearbox up. Hmmm. Started the thing - BANG! CLUNK! GRIND! Hmmm - we found the pliers :eek: - In the time honoured "lets just see if it *still* makes the noise, eventually it stopped making the noise. It would have been less than a year later when the engine had to come out (for some reason I don't recall - but it was a british vehicle, so.. :rolleyes: ) and the pliers had disappeared!! There were no holes big enough for them to escape - we could see them through one of the little inspection holes when we first put it together. The rubber bung in the inspection hole was still there... Everytime I split an engine/tranny - my father always tells me to check the tools! Twice!
/Kevin
work?
First one that I have seen this way as well. There is a pic here from TractorSmart online parts ordering:
http://www.tractorsmart.com/partspic/6659113400.gif
You can see the fingers held on by bolts, these bolt the fingers to a metal block which go through the outer cover and to the actual pressure plate. Looks like when you press in on the fingers they pull on the blocks etc. First one I have seen with so few fingers, maybe because it is a low rpm application? Mechanically it is the most straightforward from a 'how does a clutch/pressure plate work' standpoint.
I stopped by the dealers yesterday and picked up a new clutch disk, pressure plate, pilot bushing, pilot bushing oil seal and throw out bearing .. a little over $220.
Last night I pulled the pressure plate and flywheel. The clutch disk was worn more that I originally thought, just starting to get to the rivets on one side. The flywheel bolts were, surprisingly, not that tight but had a 'keeper plate' where you bend the tabs to keep them from backing out. They also look like shear bolts in that they have a narrow area just down from the head of the bolt. I expected the flywheel to be harder to pull as well but it actually just walked right off.
The pilot bushing was still there and did not look too bad but I extracted it anyway, the pilot bushing oil seal was pretty much dust and pieces. On the way home from the dealers I saw a place called 'Clutch World' that advertised on their sign 'We resurface flywheels' hmmm guess I will have to give them a call :)
So now I am waiting for my service manual for torque specs, assembly detail etc (which way did that oil seal go? hmmm). So far it is going waaay too easy which means either it is going to be really hard to get back together or I have a cut/pinched finger or some other injury awaiting me ;)
Charles
   / clutch work, new pressure plate fingers or new pp assembly? #13
for me at least, that almost always makes me worry - what am I doing wrong? .... and when I'm done with a job - once in awhile - there's an extra bolt or nut or whatever that shows up laying on the floor ....."now where did that come from?" :eek: Then I spend the next hour running the whole job through my head to make sure it's an old part that got replaced but not picked up. and of course it means sweating bullets during operation for awhile hoping nothing falls apart from lack of that bolt.:mad:
   / clutch work, new pressure plate fingers or new pp assembly? #14
Charles,
In case it speeds things up for you:
Flywheel/Crank bolts - 40 to 43 ft lbs
Pressure plate/Flywheel bolts - Hmmm - manual has no torque setting! "...securely tighten cap screws.." . Cute.
Engine/gearbox bolts - 15 to 22 ft lbs
I sheared one pressure plate bolt - the ones used are NOT what in Australia are called "hi tensile". I think they are designed to shear when some goofey person applies too much oomph. They are standard M8 bolts. No grade markings, but are "necked" so they'll shear. In Australia we are metric, but have been imperial in the recent past, so there is never an issue sourcing either sizes!
My torque wrench was set for 20 ft lbs - they weren't insanely tight when I disassembled.. I didn't torque the bell housing bolts 15 to 22 ft lbs? Nah, you can't get the sodding torque wrench in there - so I made use of my "calibrated" arm!
Cheers
/Kevin
KJM said:
Charles,
Cheers
/Kevin
Thanks for the info, I did get my WSM manual today and was a bit disappointed in the lack of torque values for the pressure plate bolts. Generally dissapointed in the lack of detail on the clutch, but then I guess if you have seen one you have seen them all :rolleyes:
When working on the release/throwout bearing I found the input shaft can be pulled out... makes a great clutch plate alignment tool ;)
I had the flywheel resurfaced today, got it, the pilot bushing, oil seal and pressure plate installed. Just need to torque the pressure plate bolts and I will be able to start putting it all back together.
Should be done tomorrow, I thank everyone for their input!
Charles
Well got it all put back together today, works like a champ!
Thanks!
Charles
   / clutch work, new pressure plate fingers or new pp assembly? #17
Glad to hear you're both back to work.....
   / clutch work, new pressure plate fingers or new pp assembly? #18
charlz
Don't you feel better now knowing it is all new in there? I know I would.
Good luck
PeterT
PeterT said:
charlz
Good luck
PeterT
I do but I would like to have found it about 20 engine hours earlier.. lke when I was buying it ;) that way I could have deducted the $250+ for parts from the purchase price. The clutch was fine until I did a bunch of loader work moving dirt around. Oh well, so it goes with older equipment. I have a few more things to work over on this tractor and then I think I will be set for at least a few years :)
Charles
   / clutch work, new pressure plate fingers or new pp assembly? #20
Charles
Charles,
If the clutch was ok before you did 20 hours of loader work, I would be real suspisious that the clutch peddle adjustment was off. If the clutch was not completely engaged, you could have been wearing it a bunch on every use.
Follow the WSM on setting up the peddle height and free play.
jb
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2385 (A60432)
2385 (A60432)
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
