Traction Clutch won't disengage on my 1715
   / Clutch won't disengage on my 1715 #1
Tpprepper
Reno NV
New Holland 1715
So I go out this morning and suddenly the clutch won't disengage. My NH/Ford 1715 seems to suddenly have this issue.
Is something set wrong to do this or is the clutch frozen to the flywheel?
Thanks
Vic
   / Clutch won't disengage on my 1715 #2
Your clutch could be stuck to the flywheel from condensation forming.
This is a common problem and you can prevent this from happening if you place a block of wood between the clutch pedal arm and the underside of the step, this keeps the parts separated when not in use.
There is a hole in the bottom of the bellhousing that has a cotter pin in it that is called a "jiggle drain" and it should be kept clean, this prevents water from collecting inside the bellhousing.
   / Clutch won't disengage on my 1715 #3
Search for "stuck clutch" in Parts and Repairs to dislodge the disc if that's the problem. How long did it sit before it stuck?
Jim
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
2007 STERLING LT9500 MIXER TRUCK (A58214)
2007 STERLING...
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
