Clutch switch bad?
/ Clutch switch bad? #1
MWB1564
Pacific Northwest
2007 CK30HST
I just started my ck30 hst for the first time in a few weeks. It won't start unless I have the clutch pushed in at just the right position instead of just push it in all the way and start it. I assume there is some kind of switch to prevent you from starting it in gear. Is this a common problem, and what do I do about it? Thanks.
/ Clutch switch bad? #2
First you should locate the switch. Then a solution may be arrived at depending on the state of the switch.:D
/ Clutch switch bad? #3
As EGON said locate the switch, if my memory serves me correctly it is mounted so the peddle engages it when you push it down, and the mount may have bent just enough that it requires you to push the clutch off center to engage it.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2020 Ranger 1000 XP (A62679)
2020 Ranger 1000...
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
John Deere 6000-Series Tractor Lift Arms (A65640)
John Deere...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2013 Ford Explorer AWD SUV (A64557)
2013 Ford Explorer...
