Clutch switch bad?
   / Clutch switch bad? #1
MWB1564
Bronze Member
Pacific Northwest
2007 CK30HST
I just started my ck30 hst for the first time in a few weeks. It won't start unless I have the clutch pushed in at just the right position instead of just push it in all the way and start it. I assume there is some kind of switch to prevent you from starting it in gear. Is this a common problem, and what do I do about it? Thanks.
   / Clutch switch bad? #2
First you should locate the switch. Then a solution may be arrived at depending on the state of the switch.:D
   / Clutch switch bad? #3
As EGON said locate the switch, if my memory serves me correctly it is mounted so the peddle engages it when you push it down, and the mount may have bent just enough that it requires you to push the clutch off center to engage it.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
2014 Ford Explorer XLT SUV (A50324)
2014 Ford Explorer...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
2014 Fiat 500L Hatchback (A50324)
2014 Fiat 500L...
Probst Metal Cart (A50774)
Probst Metal Cart...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
