Clutch sudder on a DK45S
   / Clutch sudder on a DK45S #1
8NAcres
Garland, Texas
Kioti DK45S w/ KL451 Loader 1954 Ford NAA 1948 Ford 8N 1939 Ford 9N
My new to me 2006 DK45S has 383 hours on it and works fine in low and medium ranges. However, when I shift to High range and slowly let off the clutch it shudders and bucks so bad I have to slam the clutch pedal back down. If I let the clutch out super slow it will engage correctly. Is this a clutch adjustment issue?
   / Clutch sudder on a DK45S #2
Maybe, but it sound more like you are either on an upslope or have the throttle set too low. When you go into HI you need to make sure there is no load on the engine. My H does the same thing if I try to go into 5th gear on an upslope.
I was always on flat land with the throttle about in the middle of the range. It happened to me almost every time I tried to take off. I guess I could try to rev a little higher and see if that helps.
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2022 Deere 331G (A50120)
2022 Deere 331G...
2017 Chevrolet Malibu Sedan (A50324)
2017 Chevrolet...
