Clutch sudder on a DK45S
   / Clutch sudder on a DK45S #1
8NAcres
Member
Garland, Texas
Kioti DK45S w/ KL451 Loader 1954 Ford NAA 1948 Ford 8N 1939 Ford 9N
My new to me 2006 DK45S has 383 hours on it and works fine in low and medium ranges. However, when I shift to High range and slowly let off the clutch it shudders and bucks so bad I have to slam the clutch pedal back down. If I let the clutch out super slow it will engage correctly. Is this a clutch adjustment issue?
   / Clutch sudder on a DK45S #2
Maybe, but it sound more like you are either on an upslope or have the throttle set too low. When you go into HI you need to make sure there is no load on the engine. My H does the same thing if I try to go into 5th gear on an upslope.
I was always on flat land with the throttle about in the middle of the range. It happened to me almost every time I tried to take off. I guess I could try to rev a little higher and see if that helps.
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
Booster Cables (A55852)
Booster Cables...
UNUSED FUTURE 24" HYD TILTING BUCKET (A57192)
UNUSED FUTURE 24"...
Black Tip Steer Horn (A55853)
Black Tip Steer...
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
