CLUTCH STUCK
   / CLUTCH STUCK #1
BARNACLE BILL
FORD 3000
THIS SUMMER WE HAD LOTS OF "HUMIDITY" AND MY CLUTCH IS STUCK --- WON'T RELEASE. IT IS A FORD 3000. I'VE TRIED DRIVING AND BRAKING / I CHAINED IT TO A TREE --- JUST DUG HOLES. ALL THIS TRYING TO GET IT BROKE LOOSE. NOTHING WORKS. ANY OTHER IDEAS WOULD BE APPRECIATED. THERE IS A SMALL "INSPECTION PLATE (I'LL CALL IT THAT) CENTERED UNDER THE MOTOR / TRANNY. COULD I GET TO THE CLUTCH PLATE TO PRY IT LOOSE THRU THERE ??
THANKS GUYS --- BAR BILL
   / CLUTCH STUCK #2
When you were driving, etc. did you either hold down or pump the clutch pedal? Rapid pumping of the clutch while steadily applying the brake worked on late FIL's Farmall a few years ago. Only stuck clutch I've run into, and it sat for 3 or 4 years before I had to mess with it.
Ken
   / CLUTCH STUCK #3
Block the clutch in now. Run it around tomorrow and do some kinda work to warm it up good with the clutch out [dont want to overuse the throwout bearing]. ... Then let it sit with the clutch blocked in and cool. Then try your methods to break it loose. I ran my jd into a tree once ... worked great. If it doesnt break free, warm it again and try it hot. Might want to try a reverse jerk as well as forward if you have another tractor to jerk it. Be careful.
larry
   / CLUTCH STUCK #4
Good Evenin Barnacle Bill,
You might also try greasing the throwout bearing, while your trying all these other remedies ! ;):)
Makinex Power Lifter (A52377)
Makinex Power...
2012 Ford F550 (A52377)
2012 Ford F550...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
