CLUTCH STUCK
/ CLUTCH STUCK #1
BARNACLE BILL
FORD 3000
THIS SUMMER WE HAD LOTS OF "HUMIDITY" AND MY CLUTCH IS STUCK --- WON'T RELEASE. IT IS A FORD 3000. I'VE TRIED DRIVING AND BRAKING / I CHAINED IT TO A TREE --- JUST DUG HOLES. ALL THIS TRYING TO GET IT BROKE LOOSE. NOTHING WORKS. ANY OTHER IDEAS WOULD BE APPRECIATED. THERE IS A SMALL "INSPECTION PLATE (I'LL CALL IT THAT) CENTERED UNDER THE MOTOR / TRANNY. COULD I GET TO THE CLUTCH PLATE TO PRY IT LOOSE THRU THERE ??
THANKS GUYS --- BAR BILL
/ CLUTCH STUCK #2
When you were driving, etc. did you either hold down or pump the clutch pedal? Rapid pumping of the clutch while steadily applying the brake worked on late FIL's Farmall a few years ago. Only stuck clutch I've run into, and it sat for 3 or 4 years before I had to mess with it.
Ken
/ CLUTCH STUCK #3
Block the clutch in now. Run it around tomorrow and do some kinda work to warm it up good with the clutch out [dont want to overuse the throwout bearing]. ... Then let it sit with the clutch blocked in and cool. Then try your methods to break it loose. I ran my jd into a tree once ... worked great. If it doesnt break free, warm it again and try it hot. Might want to try a reverse jerk as well as forward if you have another tractor to jerk it. Be careful.
larry
/ CLUTCH STUCK #4
Good Evenin Barnacle Bill,
You might also try greasing the throwout bearing, while your trying all these other remedies ! ;):)
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2012 International Prostar (A63118)
2012 International...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
