Clutch slipping on 6520
   / Clutch slipping on 6520 #1
fritzschrag
I have a Mahindra 6520 with about 980 hours; it is almost 10 years old. The clutch has started to slip in high range when pulling substantially. Have not noticed that it slips in low or mid-range. Is there a fix available without changing the clutch? It does not appear like there is a problem in the clutch linkage, that is, you have to push the clutch pedal about all the way in to disengage the clutch. Any of you have experience: what are we looking at to have a dealer change the clutch, $1500? Thanks for any advice.
   / Clutch slipping on 6520 #2
Is your clutch pedal play adjusted to about 1" of pedal freeplay?
Thanks for responding, Lawalls Tractor. I was mistaken when I had concluded that the problem is not in the pedal adjustment. I was going by the fact that it seemed the clutch had to be pushed in all the way to avoid grinding when using the forward and reverse shuttle. I looked into it since I posted the question and found that there was almost no free play. I adjusted the little rod so there is at least an inch of free movement. After that I could not make the clutch slip. To adjust the linkage rod I took up the rubber mat and the floor platform section on the left, which made it easy to get to. I was thinking I might have to somehow remove the rod to adjust, but found that Mahindra has a real simple way to adjust, with the rod threaded oppositely at each end; you just loosen the locknut and turn the rod. I'm thankful that it was a simple fix.
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
3pt Ditcher (A50121)
