Clutch Safety Switch
/ Clutch Safety Switch #1
confederatemule
Does anyone know where the clutch safety switch is located on a 5145 Mahindra? If so, could you explain how to get to it?
Thanks,
Mule
/ Clutch Safety Switch #2
Parts schematic shows it under the footrest on the operator's platform. Left side as you are seated.
I've had debris to built up the the mounting housing on my 3525 and cause the switch not to work. After removing the debris, the switch worked.
  • 5145.pdf
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
2007 (INOPERABLE) INTERNATIONAL 9900I (A67714)
2007 (INOPERABLE)...
