Clutch Safety Switch Iseki TX
   / Clutch Safety Switch Iseki TX #1
ballaterach
Aberdeenshire,Scotland
Iseki TX1510
Anyone know what the Clutch Safety Switch actually does on the Isekis and could a faulty one cause problems disengaging the clutch?
many thanks
   / Clutch Safety Switch Iseki TX #2
As far as I know the switch only keeps the tractor from starting. You must have the clutch depressed for the engine to turn over. You have something else wrong if your clutch will not disengage when pedal is released.
Eddie
Thanks Eddie; In view of the fact that the tractor will start without the clutch being depressed can I assume the switch is 'malfunctioning'/not working at all?
   / Clutch Safety Switch Iseki TX #4
Maybe. On one of mine the switch worked but someone bypassed it since they were apparently annoyed by having to push in the clutch to start the machine. It's not a bad habit to do regardless if the switch works or not.
Turns out that the switch had never been connected since 'remanufacture' It is now !!
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2012 RAM 5500 (A52472)
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
