Clutch rod heating
   / Clutch rod heating #1
irquomai
Sneads, Fl.
ym2000
I have ym2000 that leaks fluid where the rod attached to the clutch pedal enters the bellhousing. How can I replace that bearing?
   / Clutch rod heating #2
If it is where I'm thinking, I don't think there is supposed to be any fluid. Can you post a picture?
   / Clutch rod heating #3
Yes its supposed to be dry in the bellhousing. You have either a rear main engine oil seal leaking or the front transmission seals leaking. I personally wouldnt worry about it until it starts causing problems such as clutch slippage or excessive oil consumption.
   / Clutch rod heating #4
Yet your correct there should be nothing in there. These tractors were designed to run in deep water and thus have a drain plug in the bottom of the bell housing. Its a square headed plug about 1/4 inch. I would just pull it out right now so that the fluid does not get on your clutch. Its either hydro fluid or engine oil like stated previously.
   / Clutch rod heating #5
Might be something as simple as a leaking drain plug.
   / Clutch rod heating #6
There is not a drian plug into the bell housing. The drian plug i refer to is in the bell. Its used to drain any water fluid that makes its way into there that should NOT be there
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
