Clutch replacement on a Jinma.
   / Clutch replacement on a Jinma. #1
B85
Glendale,AZ
JM354
Have 2005 35Hp. Jinma with loader and backhoe. Is it best to remove the implements first ? I feel the loader for sure but not sure about the backhoe .
Thanks, Randy
   / Clutch replacement on a Jinma. #2
When you split the tractor you have to roll the rear apart from the front. Normally I block the front wheels and engine and support the transmission and rear wheels and roll them away. It would be hard to do that with a backhoe on.
Loader definitely has to come off, the mounting brackets are in the way of the transmission bolts.
If you search in the Chinese Tractors format there is a posting titled Jinma Splitting Guide. It's based on the 354. You should find it very helpful.
Thanks QS.
Got that last year but I'm just getting to it now . Mu bad.
Aftering looking at it I think its best to pull it down to a tractor and go from their.
Randy
Not much of a righter so here are some photos of the split. She is a 354.
Only problem with the split is the clutch looks ok ? Same with the pressure plate?
Will take a better look in the AM.
   / Clutch replacement on a Jinma. #6
What were clutch symptoms before the split? Slipping? Grabby? You're right the parts look ok at first glance. A smoking gun is preferable.
Jim
Thanks Jim.
Loss of power on pump for backhoe pump slipping ?. PTO. But the drive clutch is down to the rivets. My-bad ! Was using the clutch like a car. But I learned to split the tractor.
After things get cleaned up I will go back through the adjustment . Maybe I had the PTO setup wrong ?
Randy
Most will have the front drive-shaft housing boot going bad. So I went with a pluming part. We will see if it works ?
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
