Clutch Replacement John Deere 3130
   / Clutch Replacement John Deere 3130 #1
BabyFarmer
Ontario
John deere
Im looking for some insight on how difficult and how long a clutch replacement would take in a john deere 3130? Also wondering how much would i have to replace, or wait until i see what all needs replacing? Thanks
   / Clutch Replacement John Deere 3130 #2
:welcome: to TBN
If I was splitting a tractor similar to yours for a clutch R&R I'd replace clutch,pressure plate throw-out & pilot brg. Utilizing proper stands this task isn't difficult for someone mechanically inclined
Im planning borrowing the service manual from the local dealer tomorrow i figure that will help alot. Is it best to go factory original or aftermarket parts? Thanks for the help !
   / Clutch Replacement John Deere 3130 #4
I read good reports on Hy-Capacity clutch components.
   / Clutch Replacement John Deere 3130 #5
I would also have the flywheel checked for flatness, resurfaced if required.
Since you will have it this far apart, check into replacing the rear crank seal. I did that when I reclutched my 2030, but it took a special tool to install the seal. Ask the Dealer if a special tool is needed, and if so, if you can borrow/rent it.
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
UNUSED AGT QUICK ATTACH AUGER SET (A51248)
UNUSED AGT QUICK...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
8' DISC HARROW (A51247)
8' DISC HARROW...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
1988 John Deere 310C Backhoe (A52384)
1988 John Deere...
