Clutch Removal SLT 1554 Cub Cadet
   / Clutch Removal SLT 1554 Cub Cadet #1
goodguy40
I am going to remove the transmission drive belt on my Cab Cadet. Does someone know a good way to keep the engine from turning so I can remove the clutch bolt? :(
   / Clutch Removal SLT 1554 Cub Cadet #2
I have removed my clutch twice and both times it was a relatively simple process (if you have the right tools). Before you remove the clutch, be sure to unplug the clutch from the wiring harness, this is located on the right side of hte tractor by the starter. If you don't, when you take the clutch bolt out the clutch will fall off and hang by the wires. This can cause the ires to pull loose from the clutch causing you an even bigger problem. I use a pnuematic ratchet to get the clutch bolt off. It is very difficult to get it loose with a common socket and ratchet. The bolt is tight and requires a lot of "instant torque" to break it loose. I hope this helps you some!
   / Clutch Removal SLT 1554 Cub Cadet #3
Thanks in advance.
I cannot see the thread related to keeping things still while removing the clutch bolt.
   / Clutch Removal SLT 1554 Cub Cadet #4
Impact works great for removal. For installation and to properly torque, removing one spark plug and stuffing the cylinder full of rope works to hold the engine from turning when tightening.
Actually replaced a worn clutch on the brother in laws SLT 1554 today.
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
2023 RAM 3500 4DR 4X4 CAB AND CHASSIS (A56138)
2023 RAM 3500 4DR...
Houle 48-6D-5250 Manure Tanker (A50775)
Houle 48-6D-5250...
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Club Car Carryall 1500 Diesel Utility Cart (A55787)
Club Car Carryall...
