Clutch question
/ Clutch question #1
sevilla
New England
L3830
I have a L3830 with direct transmission. The manual says to lock the clutch in the depressed (disengaged) position for storage. More than once I warmed the tractor with the clutch depressed ( I forgot to release it) and once I run a three TPI wood splitter with the clutch in that position for one hour. Did I do any damage to the clutch? Sorry if the question is stupid but I'm not too into engines in spite of my efforts. Thanks.
/ Clutch question #2
Sevilla,
The only thing you did was give the throwout bearing a good run in. I doubt you did any long term wear to it but I would not make a habit of using the clutch latch when doing stationary work.
BTW - the latch is there to keep the disc from sticking to the flywheel and pressure plate faces when stored for a long while.
