Clutch problems?
/ Clutch problems? #1
calbug
Georgia
Branson 4720i
branson 4720i 4x4 /loader/shuttle shift won't hardly pull off from a dead stop even in low range, 1st gear. im thinking clutch adjustment maybe??? all fluids full and i serviced it @ 2 months ago. wont move at all in 2nd range. need advice.
/ Clutch problems? #2
Since it is a gear drive trans (not hydrostat) nothing else comes to mind but clutch slipping. I assume the engine revs out/ isn't bogging down while this is occurring? If engines is straining, it is possibly an issue with brakes being engaged or another issue not allowing the machine to pull. It's a little unusual if symptoms of a slipping clutch start suddenly. For instance, usually you would notice the clutch slipping while in high range/or high gear and notice that a lower range/gear worked fine. As time passes it requires lower and lower gear rations to keep the machine pulling properly.
Has the above described scenario been present or did this issue happen suddenly ( worked fine then all at once it only pulled in low range/1st gear)? There is usually some adjustment available through the linkage from the clutch pedal. Letting some slack out in the linkage would possibly allow the clutch to better engage. The pedal should always be adjusted with a small amount of free play/movement before it begins to disengage the clutch, otherwise premature clutch wear can occur. If the operator "rides" the clutch and allows it to often slip, this too will cause premature failure.
Your manual should cover any type of adjustment that can be done. Also look at the pedal linkage and make sure nothing is keeping it from free/full movement.
/ Clutch problems? #3
Not sure of your unit but my kubota has 1" of play in the clutch peddle...2" and things don't work correctly.
/ Clutch problems?
the low range slipping was overnight but it did slip a little in higher gears before. i will try to adjust linkage and see what happens. i make an effort to not ride the clutch so i hope clutch isn't shot.
/ Clutch problems? #5
If it has been slipping for a while you are most likely in for a new clutch. I would certainly try some adjustment, you may get lucky but I wouldn't be too optimistic on how much more service you will get out of it. A new clutch will require the tractor to be split at the engine and bell housing. Not an overwhelming job for a shadetree mechanic. You will probably have to take the loader off and an extra person to help separate and pull the halves back together but it is probably an easy weekend job. A cab may create a bigger job but probably still a weekend project.
Looks like a pressure plate, disc and t/o bearing runs about $300 online....I would replace the pilot bearing while I was in there too. If you have a dealer do the job for you, expect to spend $1K or so
/ Clutch problems?
runs like new after i adjusted clutch linkage, no play in pedal before, now i've got @1". being it's been slipping worried clutch may prematurely fail now. maybe luck will be on my side.
/ Clutch problems? #7
... pressure plate, disc and t/o bearing ....I would replace the pilot bearing while I was in there too....
Glad you got it working. If you have to replace the clutch at a future date (we had this after adjusting the clutch since the damage was already done) in addition to those things Kernopelli mentioned, I would also suggest having the flywheel resurfaced. If it is a step-down flywheel you may want to call a shop before you take it to be sure they can do that.
/ Clutch problems? #8
not slipping as the cluch peddel doesn't release so shifter can't ingage was working fine then next time I started it the clutch wouldn't ingage so no ****ting ???have you ever run across this problem ?
2001 CATERPILLAR 924G WHEEL LOADER (A65053)
2001 CATERPILLAR...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2018 Mitsubishi Mirage Hatchback (A64557)
2018 Mitsubishi...
