Clutch problem
/ Clutch problem #1
Andrew Nield
France eu
Iseki TX 1500
**** o can any one help please ,i can not engage the gears on my
iseki TX 1500,its starts to make a grinding noise ,when i try to select any gears ,its been standing for 3 months only .
/ Clutch problem #2
Are you sure that your clutch cable is adjusted properly?
/ Clutch problem
Hello
Bilko, thank you for your reply, this iseki TX 1500 does not seem
to have a clutch cable,do you have any more thoughts please.
Thanks Andrew.
/ Clutch problem #4
My TX1500 has a rubber inspectoin plug for the clutch on the right hand side of the bell housing. Remove it and look in there and operate the clutch pedal and observe the movement of throughout bearing against clutch fingers. My clutch fingers were worn out and caused it to not engage.
/ Clutch problem #5
Sounds like the clutch is stuck. When leaving unused for that long, the pedal needs latched down. Look for a hook that will hook to the pedal when it is pressed down. If it doesn't have a hook, use a block of wood.
Do a search for stuck clutch. You should get several hits. They will tell you how to un-stick the clutch.
/ Clutch problem #7
There should be 30-40 mm free play on the peddle if it is more than that look in the inspection hole for worn fingers
mine wore them down when the release bearing ceased up
if it looks ok then there is an adjustment on the linkage that the peddle is connected to hope that helps
/ Clutch problem #8
There are several ways to unstick a clutch.
1.Run a pto implement such as a tiller or mower with the clutch depressed. (worked a couple times for me)
2. Put in high gear & hit brakes evenly. Be careful that you don't turn sharply(worked quite a few times for me)
3. Split the tractor (I've had to do this a couple times)
/ Clutch problem
Thank you Len,
for your help with the clutch on my iseki
i put a implement on the pto ,like you said and yes it did free the clutch ,
Thanks again,good luck , Andrew in France.::
/ Clutch problem #10
That's good to hear! Glad you were able to get it fixed without having to spend any money.
