Clutch or loose belt?
   / Clutch or loose belt? #1
ttener
Rockville, md
NH 33D
Toro Z master turbo force 52 with Kawasaki FX691 motor. Older - maybe 10 years old.
I’ve replaced all belts before, but not recently- maybe they are 2-years old now.
stumped… when I engage the blade PTO it’s like it’s struggling to get up to full speed. It doesn’t seem to bog the motor down, just won’t crank the blades up all the way up to cutting speed. Sometimes it will catch, other times not.
I looked for anything in the belt path - clear. I can turn the blades by hand and watch the clutch turn, but it makes a friction sound. Not a grind, just a metallic friction noise. It’s pretty ez to turn the blades tho - so I think spindles are all good. Recently greased idler arm.
Deck is relatively clean, no issues there, although I’ll clean it up for kicks.
I guess I need to get corporate (wife) out to engage PTO in park and watch the clutch, belt action tomorrow.
Any advice much appreciated!
UPDATE: I pulled the blades to sharpen while I was under there. 1 blade was bent! I’m hoping that was just enough to throw it off! I’ll try it tomorrow
   / Clutch or loose belt? #2
Sounds like the friction plate on your clutch is needing adjustment. Some you can adjust, some you can, some you cannot.
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
1987 Ford F800 Fire Truck (A51692)
1987 Ford F800...
