Clutch or loose belt?
   / Clutch or loose belt? #1
ttener
Bronze Member
Rockville, md
NH 33D
Toro Z master turbo force 52 with Kawasaki FX691 motor. Older - maybe 10 years old.
I’ve replaced all belts before, but not recently- maybe they are 2-years old now.
stumped… when I engage the blade PTO it’s like it’s struggling to get up to full speed. It doesn’t seem to bog the motor down, just won’t crank the blades up all the way up to cutting speed. Sometimes it will catch, other times not.
I looked for anything in the belt path - clear. I can turn the blades by hand and watch the clutch turn, but it makes a friction sound. Not a grind, just a metallic friction noise. It’s pretty ez to turn the blades tho - so I think spindles are all good. Recently greased idler arm.
Deck is relatively clean, no issues there, although I’ll clean it up for kicks.
I guess I need to get corporate (wife) out to engage PTO in park and watch the clutch, belt action tomorrow.
Any advice much appreciated!
UPDATE: I pulled the blades to sharpen while I was under there. 1 blade was bent! I’m hoping that was just enough to throw it off! I’ll try it tomorrow
   / Clutch or loose belt? #2
Sounds like the friction plate on your clutch is needing adjustment. Some you can adjust, some you can, some you cannot.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
