Clutch on a Iseki TS2210
   / Clutch on a Iseki TS2210 #1
andyfsisk
Nashoba
Iseki TS2210
I own a Iseki tractor ts2210, I parked the tractor after running it. Went to run it again the clutch won't work on it. Haven't tried anything yet not sure where to start. I don't have an owners manual or a parts book so any advice or help would be much appreciated.
   / Clutch on a Iseki TS2210 #2
What do you mean it won't work? The tractor won't go or the
clutch will not disengage? If it won't disengage then clutch disk might be
rusted to flywheel. If its rusted you could remove the rubber inspection
plug on the side of the bell housing and reach in with a long screw driver
and try to pry it loose. You could also put a chain around a tree and then hook
it to the rear of the tractor then put tractor in high gear not low gear
push clutch pedal in and then start tractor to see if clutch will come loose
when tractor tries to go forward with clutch pedal pushed in.
Some people have just pulled tractor against a tree and did the same thing.
SRECO SEWER CLEANING SYSTEM JET VAC (A52708)
SRECO SEWER...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
Butterfly Artwork (A55758)
Butterfly Artwork...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
