Clutch life?
/ Clutch life? #1
gerard
Syracuse NY
Kubota L2500DT w/FEL
Have a kubota L2500 gear tractor, purchased new in 2000. I know this is a little like asking how many miles you can get out of a set of tires, but I was wondering how long I can expect to getout of the clutch assuming normal use. Normal use being about 25% dirt/loader work, the remainder bushhogging, snowblowing/plowing, and arena dragging. I have about 1100 hours now. Any experience or guestimates of a range?
/ Clutch life? #2
No telling, we have tractors over forty years old with the original clutch.
/ Clutch life? #3
When selling my L3650 the dealer estimated a clutch on a FEL tractor would last 1500 to 2000 hrs.
/ Clutch life? #4
I have well over 1600 hours on my clutch and its never needed its first adjustment yet. (the freeplay is still about where it was when the tractor was new)
I expect to get several thousand hours or more easily out of my clutch.
It also has a lot to do with the operarator.
I've seen guys that can make a clutch last forever, I've also seen a few that could burn up a clutch in no time.
/ Clutch life? #5
depends a lot on the operator------------usually a long time-
/ Clutch life? #6
If you have the urge to "ride the clutch" then your probably in a gear that's too high for the task.
/ Clutch life? #7
My old 2600 is just about ready for a PTO clutch at 2000 hours. Of course, it will get both clutches changed when it happens. Even though the drive clutch has never slipped, I won't put it back together without changing them both.
/ Clutch life? #8
I've seen people ride them out in less then 500 hours! I've also seen them go 7,000 hours and more.
I do like the one post where the dealer stated the 2,000 to 3,000 hours for the noted uses of a loader. That is a good number for an average and one that fits with what we see in the shop.
Not only is clutch life different for owners, it makes a differenc on the whole machine!
/ Clutch life? #9
The one and only clutch failure I've had experience with was right at 3600 hours, and that was on a rental that had been beaten to an inch of it's life. If I recall it was a 30 something HP Kubota.
/ Clutch life?
Thanks for the replies, gave me some good "rules of thumb" which was exactly what I was looking for. I should be good for awhile longer yet me thinks.
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
Informational Lot - Financing (A63688)
Informational Lot...
John Deere 410D Backhoe (A62679)
John Deere 410D...
207280 (A52708)
207280 (A52708)
