Clutch in YM276D
   / Clutch in YM276D #11
Eric,
I lived at the end of Troxell Road just past Deception Pass for years and can envision your drive. Thanks for the information. Someone mentioned using a brush hog to help. At the farm, there is a 60" brush hog that should really be a bit much for the tractor, but that sounds perfect to get it unstuck.
Right now the Powershift is working or at least the auction stated that; however, in my mind that means it's stuck in a particular gear on the manual part of the transmission. Can someone change the gear without the clutch working? Some truckers claim they can shift gears without using a clutch, but that sounds different than changing a gear in a tractor.
IF it's stuck in a Power Shift range, then getting to another range isn't to hard. Just have the engine at idle on a flat and level surface with the Power Shift in it's Neutral. Gently move the gear shift out of that range and pick another. Now use the Power Shift in the new range.
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2010 FORD F-150 (A58214)
2010 FORD F-150...
large capacity skid steer bucket (A56857)
large capacity...
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
500 GALLON FUEL TANK ON SKID (A52708)
500 GALLON FUEL...
