clutch for a Daedong L2601
   / clutch for a Daedong L2601 #1
Thud
Georgia
Cub Cadet Yanmar Sx3100
Hi All,
I am looking for a part source for Daedong tractors, I have grey market (to US) Daedong tractor L2601 which has daedong 1400cc 3 cyl diesel and 4 wheel drive, looks very similar to a LK3054 but only has 1 stage clutch. So I am looking for parts for the Clutch, the friction plate, throw out bearing , transmission main shaft seal (cause of my clutch problems) and maybe while I have torn apart the pressure plate and diaphragm spring (attached to pressure plate). Can anyone help me out?
Thanks,
Thud
wanted to add some pictures so maybe they might look familiar to another model.
Thanks
Thud
   / clutch for a Daedong L2601 #3
it might be easier to find a clutch shop that rebuilds clutchs and have the clutch refaced and the pp reworked and u should beable to get the bearings and seal from a parts store like napa
Thanks for the advise, I may have to end up doing that, but I have to believe that Daedong made this same clutch for other tractors that were shipped to US, but the things aren't marked with a part number, that would be too easy huh?
Thud
   / clutch for a Daedong L2601 #5
I agree on the clutch parts not being a hard issue to solve. A Kioti dealer may be able to help with the seal, especially once you have it in hand and can use it to reference any numbers or compare to a Kioti part. If that fails, try contacting a "Daedong dealer" like New and used Tractors and Implements, spare parts and service. they may be able to look the part up for you, order and ship it to you.
Thanks for the information, I am checking with a dealer now to see if he can help. I have also found that AU tractor parts site, but haven't gotten any reply to my email, so I may have to call to see if they can help.
Thanks
Thud
   / clutch for a Daedong L2601 #7
I'll have a look at the parts program tomorrow for you, we have both Daedong and kioti so should be able to find the parts numbers you need.
Your local kioti dealer will be able to get them, they are all the same tractor!
If you can pm me your email add, I'll send through what I can
Thanks Andrew,
I sent you my email via pm, I really appreciate this, the Kioti dealer I was talking to told me that my tractor was not a Kioti but a Kubota but I know that is wrong so if I have Part numbers I can surely find a dealer to order them for me.
Thanks again.
To follow up on this,
I found a clutch plate on ebay it was for a Kioti LK2554 the part number was T38284-14301 and it was an exact fit (although the people I bought it off said it for a LK2254 which as far as I could tell doesn't exist ;-). The throwout bearing (thrust bearing) was a Koyo RCT45-1S, and I found that through a bearing supply house, the transmission seal was metric oil 25x52x10 type TC and I bought them through a oil seal supplier in California. So I should be back in business soon.
Thanks everyone for their information esp. Andrew for taking the time to send me some alternative part information.
Thud
   / clutch for a Daedong L2601 #10
Good to hear you've got it all sorted!
Case 830 Tractor (A50514)
Case 830 Tractor...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
Gator (A50324)
Gator (A50324)
