Clutch - dunce question
/ Clutch - dunce question #1
Ron25
Bronze Member
I have an Iseki 1910 that I have split to repair the clutch. I faced the flywheel, plate, had the finger tig'ed and milled and found a new disk. It has been over a month since I've taken it apart and can't recall which way the disk goes. There is basically a flat side and raised side. Which side goes to, say the flywheel?
/ Clutch - dunce question #2
the raised side goes to the realease bearing the flat side goes to the flywheel a little trick i do also is grease the realsease bearing if it doesnt have a grease nipple drill a small hole in back and fill it full of grease with a needle then use a small amount of silicone to fill the hole it seems that they never put enough grease in them don
2012 Ram 4500 Truck, VIN # 3C7WDLFL4CG183200 (A61165)
2012 Ram 4500...
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2016 Dodge Grand Caravan van (A61569)
2016 Dodge Grand...
Toro Workman HDX-D Utility Cart (A61567)
Toro Workman HDX-D...
