Clutch does not disengage
/ Clutch does not disengage
I got it! I took the dust cover underneath the clutch cavity and with a punch, tapped a few times until the disc moved.
I tried the stomping the brakes and clutch pedals while moving , all it did was either keep moving or stalling(depending on what gear i was in)
Amazing how a little rust will hold so much torque.
/ Clutch does not disengage #12
Clutch manufactures are now using more metallic linnings as compared to the linnings asbestos favored in the past.
Best to block or tie clutch pedal down in the release position if tractor going to sit a while. This is especially true in areas of high humidity.
george
/ Clutch does not disengage #13
</font><font color="blue" class="small">( That surprises me, Dave. I would have thought you'd just stall the engine before anything else broke. )</font>
Bird, it certainly surprised me as well. I had done this so many times that I think I was a little hasty and careless. Many of the Yanmars have excellent wet disk brakes...and I think that contributed to the issue. /forums/images/graemlins/tongue.gif
/ Clutch does not disengage #14
</font><font color="blue" class="small">( I got it! I took the dust cover underneath the clutch cavity and with a punch, tapped a few times until the disc moved. )</font>
Glad you got the clutch unstuck. My Kioti has a little hook that flips up when you depress the clutch to hold it. Maybe you could create a small hook like that to keep yours depressed when not in use. John
Yep. I think i will put something like that in place instead of the stick I have wedged in the stop adjustment.
207280 (A52708)
207280 (A52708)
Rhino DB150 (A57148)
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
1990 TRAILMASTER CRUDE TRAILER (A60736)
1990 TRAILMASTER...
2001 John Deere 6210 (A60462)
2001 John Deere...
2014 FORD F-150 (A60736)
2014 FORD F-150...
