Clutch and PTO operation
   / Clutch and PTO operation #1
DViau
Frelighsburg, Quebec
Kioti CK-20HST
I am using my new CK20-HST with a rear mower. My question is: is there a way to shift from Low to High without using the clutch because if I use it, the PTO Stop and so I have to reduce speed in a way to have the PTO running again (because I don't want it to have the PTO back at full speed).
Need your advice.
Thanks
Denis
   / Clutch and PTO operation #2
Need your advice.
Thanks
Denis
If you can, it'll be in your tractor's manual.
If I'm reading your post correctly, you want to shift into another speed range without reducing RPM. I'm not so sure that's a good idea...that could put a shock load on your PTO drive and the implement.
I mean when I have to climb a hill and I have to have my tractor on low gear, If I have to use the clutch that will stop the PTO and so I should reduce the RPM in a way to have the PTO back on and not have a shock on the PTO. I was just wondering if there is a more intelligent way to do it.
   / Clutch and PTO operation #4
Usually you need to stop to change ranges. Check the owners manual to be sure. If it says to stop and you don't, it could lead to damage.
jb
jb
Just to be sure that you understand me well (sorry, french is my usual langage), of course I will stop moving prior to change from High to Low. So once I'm stopped, Do I have to use the clutch to change from High to Low. If I do, that will stop PTO. Don,T hesitate to ask for mere clarification.
Thanks again eveyone
   / Clutch and PTO operation #6
Just stop the machine clutch in, switch gears(ranges), then slowly let the clutch back out if the implement is still spinning and if the implement has slowed or stopped then idle the engine down before letting the clutch pedal back out.
Always stop to change ranges and always clutch to change ranges but you don't always need to be at idle to repower the PTO.
   / Clutch and PTO operation #7
Like Highbeam said.... just stop.....depress your clutch, change gear range....and SLOWLY let off the clutch to engage the PTO again....
Good Luck!
   / Clutch and PTO operation #8
YOU DON'T USE THE CLUTCH TO STOP THE PTO!
Why doesn't this fact sink in? If the PTO is engaged and you push in the clutch, you will hear a horrible grinding noise. You only use the clutch to engage the PTO, to disengage it you just slide the lever back. As long as you are stopped and your foot is fully on the brake so the vehicle does not roll you can switch between gears without the clutch even when the PTO is spinning. The beauty of HST...
I am not sure if it is the same for a CK30 but we are talking about a CK20 which I have and that is the way it works.
   / Clutch and PTO operation #9
Need your advice.
Thanks
Denis
You state that you have an HST. If this is so then stopping by taking your foot off the HST pedal stops the gears. You can shift without a clutch then. I assume Kioti is similar to other makes. If you don't hear it grind your OK.
You may also want to post this question in the Kioti forum.
Thanks you all for the tip. Of course I will read cover to cover the manual but nothing worth the experience of all.
Denis
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2000 GMC C7500 Flatbed Truck, VIN # 1GDM7H1C4YJ505285 (A51572)
2000 GMC C7500...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
