Clunking noise under steering wheel
   / Clunking noise under steering wheel #1
Matlax
Kioti CK2610 HST
EDIT: I’ll add that I just had a third function installed. I can’t say for certain if the noise was there before or not. I figured I’d try to get all inputs first. Is there something they could have done during the install that would cause what I’m hearing?
Hi, new Kioti DK5310SE (hydro) with 7 hours on it. I noticed when I idle it down to cool down before shutting it off, it makes a random clunking or knocking noise under the steering wheel. It has nothing to do with turning (tractor is parked). I also hear and barely feel it at 2k RPM. There’s some casing there but I’m not sure what it is (hydro sump?). It’s right under the steering column in the pics. Didn’t happen on my 2019 CK2610 hydro. Any thoughts? Thanks!
   / Clunking noise under steering wheel #2
Better call your dealer right away
willy
Thanks Willy. Anyone else? Air in the system?
   / Clunking noise under steering wheel #4
Doubt its air..
I’ll add that I just had a third function installed. I can’t say for certain if the noise was there before or not. I figured I’d try to get all inputs first. Is there something they could have done during the install that would cause what I’m hearing? Thanks again for any thoughts.
   / Clunking noise under steering wheel #6
I discovered the same issue today on my new DK 4720 with only 3 hrs on the meter... and after running it for about an hour. Used the tractor today for the first time. Any word from your dealer?
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2003 Big Tex 10PI...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
NEW TRAILER PARTS & 20 CONTAINER (A58216)
NEW TRAILER PARTS...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
