clunk on ignition switch turn on GC2300
   / clunk on ignition switch turn on GC2300 #1
RobbyB
GC2300
When I first turn the key on I hear the fuel pump and I get a mechanical clunk. When I shut the engine off I get the same sound after the engine is off. Is there a mechanical switch tied to the electrical system. On start up some times it takes 3-4 turns of the switch before the starter engages. Engine starts with no problem and the battery is new and charged. Seems like there is some mechanical switch for the electrical system.
   / clunk on ignition switch turn on GC2300 #2
I would imagine the clunk you are hearing is the fuel shutoff solenoid. As far as not engaging the starter several times before starting, that is possibly a low voltage condition to the starter solenoid, or resistance in the solenoid itself. It could also be poor high amperage connections on the battery or starter.
Thanks for responding. New starter so I doubt it is the solenoid but your point of high resistance to the solenoid is a good point to check. Possibly key switch?
   / clunk on ignition switch turn on GC2300 #4
Could be the key switch, but more likely resistance in the numerous safety switches or resistance in the high amp cables (battery, ground, starter).
If it's low voltage on the solenoid wire, an easy fix is to add a simple relay that provides power to the solenoid directly from the battery, rather than through all of the safety switches.
   / clunk on ignition switch turn on GC2300 #5
Might check to see if there is a "starter relay" in circuit.... Electrical diagram in manual would tell you this.... I know in GC 1700 series the is a "starter relay" that triggers the solenoid on starter.... Other option may be internal (not visible ) corrosion in battery/ground cable or poor electrical connection at battery or where ground cable attachés to chassis.... Might try putting test lamp on the initializing terminal of solenoid to see if solenoid is actually getting signal to energise when key goes to start...
This type of tool could be your best friend when troubleshooting....
Thank you. I will test but it makes sense that there would be a starter relay. I just need to find a wiring diagram for the GC2300
   / clunk on ignition switch turn on GC2300 #8
Wiring Diagram: MF 2300
Replaced my key switch a couple years ago. Showing a bit of corrosion and intermittent failure to crank.
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
Carnival Ticket Booth (A51691)
Carnival Ticket...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
