Club Cadet 124 question x2
   / Club Cadet 124 question x2 #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Does any one have a wiring diagram for the CC124? I bought it dismantled and had to replace the cam shaft and as we were putting it together did not know how the generator hooks to the voltage regulator, the seller had done nice job of marking other wires to starter etc but not to the regulator. Or where can I obtain a manual?
Second: Need to know the belt size to run the rear mounting rototiller. Also schematics as to how it is routed, if available?
Thanks
Thank You rcbe, that was an excellent link for the information needed. I still am searching for information on the belt needed to run the Cub rototiller.
Thanks Again
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
PREVIEW DATES AND TIMES (A54865)
PREVIEW DATES AND...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
