Buying Advice Close to Buying a Mahindra 6075 Cab Looking for Info
   / Close to Buying a Mahindra 6075 Cab Looking for Info #1
GunPilot64
Southeast Alabama
Mahindra 6075 Cab
Hello, all. This is my first post on TBN. I知 looking at purchasing a 6075 cab in the next few weeks. I live in south Alabama, so the cab will be nice for the Alabama heat and the dust/pollen while mowing. I will use the tractor for mowing, grading, FEL work, and moving round bales of hay.
I致e read all the specs and looked at pretty much every video on YouTube regarding this tractor. Also, I致e looked at all the threads on here I can find. Now, I知 looking for some firsthand info from owners/users regarding the 6075 tractor (cab or open since the performance and specs are largely the same).
   / Close to Buying a Mahindra 6075 Cab Looking for Info #2
Re: Close to Buying a Mahindra 6075 Cab有ooking for Info
I have a 8560.
It is a stout tractor for loader and implements.
Have to keep the radiator and cooling coils blown out for AC to cool in hot weather.
Radiator Genie is best thing I have found.
Thanks for that input. I’ll definitely look into the Radiator Genie. I had a chance to look at a 6075 at the local dealer yesterday. I was very impressed. It had two air filters for the cab. One above each cab door, and they looked very easy to access. Also, the radiator has screens that slide in and out in front of and behind the radiator. Is this a similar set up to the 8560?
   / Close to Buying a Mahindra 6075 Cab Looking for Info #4
Those screens are a pre filter before and after the radiator. Most tractors today have them. Helps to keep the radiator clean. Just make sure to keep them clean in the hot summertime. I keep a paint brush with me when hogging to sweep away the debris from the tractor. Newer tractors have very small fins in their radiators thus the need to pre filters. Air conditioning on a cab tractor in the hot summertime taxes those cooling systems. They work fine as long as everything is relatively clean.
Good to know. Thanks!
   / Close to Buying a Mahindra 6075 Cab Looking for Info #6
What he said.
The AC radiator will plug up quick when mowing tall stuff.
Keep it clean & AC should work fine in LA!
Clean the radiator with low pressure water or air to prevent damaging the fins.
It is just a ongoing thing, like checking oil and fluids.
Yeah, you know how it is in LA!
What he said.
CHAMPION AIR COMPRESSOR (A55745)
CHAMPION AIR...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2015 PETERBILT 389 SLEEPER (A55745)
2015 PETERBILT 389...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
