Clogged Valve Stems
   / Clogged Valve Stems #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
My ATVs are getting old and the tires slowly leak air -- especially when they sit unused for a few weeks. I have had success in the past with sealants or fix-a-flat. Last time I added a little fix-a-flat the valve got clogged and now I can't put air into the tire. Is there an easy way to clean these out and open the airway?
Thank you for your help.
   / Clogged Valve Stems #2
Rather than trying to clean it - just remove the old core and replace with a new one. The removal process will clean the stem and the new core will, once again, seal in the air.
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
