clogged sump filter
/ clogged sump filter #1
Paul Luke
john deere 950
I have a John Deere 950 4x4 with a backhoe attachment I have an ongoing problem with the hydrolic filter being clogged with a white googy substance . I have cleaned and changed the filter many times . I have drained and cut the fluid 50 50 with disiel and ran it for 30 min . It runs for 2 hours and clogs up aain . Does anyone know what I can try to fix this? Any help would be appreaciated .HELP
/ clogged sump filter #2
Sounds as if trans case/hyd oil contains a bacteria or fungus. I suggest to utilize some hyd oil additive that contains Biocide.
/ clogged sump filter #3
white usually means water getting in. don't know your particular tractor but any way coolant could be flowing into the trans oil. how are the shifter boots on top if open station. after running it does the oil look milky.
I wouldn't have thought water alone would plug up a screen but the algae theory makes sense.
1075 (A64280)
1075 (A64280)
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
Unverferth 330 (A64119)
Unverferth 330...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
Mini rock grapples (A61567)
Mini rock grapples...
