Clogged Kitchen drain
/ Clogged Kitchen drain #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Well guys for the second time in 29 years since I built this house my drain from kitchen sink is stopped up. It is a sched 40 1-1/2" PVC and it drops 3" in 29'. The first time it clogged it did have a bit of a belly in it and I ended up cutting out a section and it was jammed with typical kitchen "goo". No disposal but dishwasher dumps into it above the trap, We have always been careful, don't dump grease down it and have a screen over the two sink drains to catch food scraps. We probably have NOT done a good enough job of wiping dishes before they go in washer.
so I've snaked it twice in both directions and done the baking soda/vinegar routine a couple of times. Snake goes through but I'm afraid it is just punching a 5/8ths -3/4 hole and the minute I flood it, it seals up again.
Before I cut the line out, anyone have any success with an of the liquid plumber stuff? There are a lot of products out there all claiming to be the best. The baking soda/vinegar thing works well but the issue is NOT in the trap.
appreciate any thoughts? Think I've got too much drop with 3" in 29 ft?
By the way I've also used one of those plungers made for sinks and the only thing I get out of that is exercise!
/ Clogged Kitchen drain #2
We use a liquid that is available only from plumbing supplies, big barns don't sell it because it is nasty stuff and caustic but it breaks down everything.
Don't recall the name but sure you will have the same thing with a local name, this has cleaned out horse hair (daughters thought washing horse rugs in the washing machine when we were not home a good idea) and the usual 'cholesterol' build up on the pipes.
Don't get it on yourself as it is nasty stuff and wear safety glasses.
/ Clogged Kitchen drain #3
I have used liquid plumber and it was successful.
Poured down drain, ran water until sink was half full then waited......
25 minutes later I heard a gurgle and down went the water.
Changed my disposal habits and have had no issues since.
/ Clogged Kitchen drain #4
I used hot water-sometimes a sink full at a time- with the snake in the drain to help with the buildup. Otherwise (and honestly the best for this) it’s hydrojet time.
/ Clogged Kitchen drain #5
Is there no clean-out at the bottom of the riser below the sink?...
I would use close to boiling water then open the trap and temporarily cap the line (and vent etc.) and use a hose (with some pressure) at the clean-out...
/ Clogged Kitchen drain #6
Can’t remember who makes them but we use an expanding in line thing that screws on a garden hose and you stick it and the hose in the pipe. It seals the pipe and sprays water inside the pipe to clear the clog and have had really good results. I used liquid lightening one time but makes your house smell like sulfur for a while and you aren’t supposed to get any on you. I think you have plenty of slope in your line. It’s it only the second time in almost 30 years, you have a lot better luck than me.
/ Clogged Kitchen drain #7
Last time mine clogged, discovered toddler grandson helped do dishes by putting a few chop sticks in there. Aha, easy removal, and now able to snake a pipe with a near 90 degree angle about 4' into the corner under the sink. An almost impossible task.
After trying a few chemicals, I gave up and thought outside the pipe, so to speak. I rigged a nozzle to adapt to my shop vac, and away I sucked. It took over an hour to finally clear the pipe. I believe the main culprit was swollen grain debris, i.e., oats and rice, mixed with cold grease from when the family lived with me and cooked differently than I do.
Now days I am religious about monthly treating both sides of the sink with a dose of baking soda chased by cleaning strength vinegar, and hot water. Also, sinks will clog when the intake is small. Which is why it is also a good idea to fill the basin with water to insure a good flush.
My final word of advice, do not plunge kitchen sinks.
I heard a story about a clogged sink due to the vent stack being filled to the brim with acorns.
/ Clogged Kitchen drain #8
Can’t remember who makes them but we use an expanding in line thing that screws on a garden hose...
That would be a Drain King, available locally at most of the box and hardware stores. I have one as well.
/ Clogged Kitchen drain #9
/ Clogged Kitchen drain #10
OP, Your drain setup seems similar to mine in length, drop, and the feed from a dishwasher. I had a droop in mine and it started to clog regularly. Shimming it up helped but it still clogged even though it would run well for weeks or months. I was using a 1/4" snake that you rotate with a drill. I got a 3/8" hand rotated drain auger which solved the problem ($20 at Home Depot in Canada). Although the 1/4" snake seemed to be cleaning the pipe and ran easily through, I suspect it was drilling a hole through the plug of muck. The 3/8" does a much better job. It did clog a few weeks after using the 3/8", but I cleaned it again it has been good for about 4 months since then. I am sure the 3/8" cleaned a lot more out of the pipe than the 1/4".
Perhaps a thicker snake may work for you.
/ Clogged Kitchen drain #11
I generally avoid any of the chemicals just in case you have to cut the line later.
You have general crap build up from years of grease.
I would first try a thinker snake--perhaps even rent one.
If that does not work, Hydrojet.
/ Clogged Kitchen drain #12
I use a liquid I get from Wally world that is for campers/rv's. To keep drain clear. It's a microbial holding tank solution. Put it in drain and flush down pipe with a few cups of water last thing before going to bed every 2 to 3 months.
/ Clogged Kitchen drain #13
Is a "thinker snake" a smart snake ? Does it operate on WiFi? :)
I had a problem in a house I rented out, the lousy tenant had put steel wool and lard down the drains. I rented a sewer snake with a cutter head about 1" in diameter. Only cost like $20 for the weekend.
Use PPE - a throwaway poncho, rubber gloves and boots.
/ Clogged Kitchen drain #14
Us country folk with septic tanks have to be careful with the liquid plumber stuff....Hard on the good microbes.
/ Clogged Kitchen drain #15
You don't have enough drop. It's supposed to be 1/4" every foot. .25 x 29 = 7.25"
/ Clogged Kitchen drain #17
/ Clogged Kitchen drain #18
35 years of property maintenance and the balloon/garden hose is my go to... brand names like drain king.
Had some difficult grease packed lines and hooked hose to water heater.
Chemicals have their place but if on septic be careful...
Drain Care has done me right being proactive... a little in the traps a couple of times a year... it is also sold by Zep at Home Depot.
For the difficult tasks I have a compliment of professional Spartan tools... full augers with cutting heads and 230' of cable...
That said it is amazing what a properly placed garden hose can do...
/ Clogged Kitchen drain #19
ClogHog is another popular jetter. Many of these look similar and are likely just rebranded, so choose the model that matches your pressure washer size and check shipping costs to get the best deal.
/ Clogged Kitchen drain #20
I had a plugged kitchen drain that has a long run and I couldn't get a snake to the blockage. After a bunch of research on drain cleaners I found one at Walmart for about $11. Treated the drain in the evening and ran hot water the next morning to flush it through. I did this last November and haven't had a problem since. High ratings on most reviews for it.
Main Line Cleaner | Instant Power
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
Metaltech Climb and Go (A64553)
Metaltech Climb...
