Climate Control Air Compressor for Shop Use
   / Climate Control Air Compressor for Shop Use #11
All the air compressors for use with HVAC controls that I encounter are 3 phase. is that what this is and will that be a problem for you?
Apart from that it should work fine for you. Good luck.
Professor, the compressor motors are single phase, and can be wired for different voltage. The driers are small, 115 volt plug-ins.
   / Climate Control Air Compressor for Shop Use #13
This sounds interesting to me. It sounds like George has a good handle on it. I would follow his suggestions. I know they are made for constant use so should last a long while.
   / Climate Control Air Compressor for Shop Use #14
Timbuck2 I know this is an old thread but any updates?
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
Tandem Axle Rear...
2020 Dodge Grand Caravan SE Van (A48082)
2020 Dodge Grand...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2005 Toyota RAV4 SUV (A48082)
2005 Toyota RAV4...
