Clickity clack, clickity clack
   / Clickity clack, clickity clack #1
RCannon
thumb of Michigan
TC33D
Thats how my new tractor sounds when I mow.
Just took delivery of a TC33D with 72inch MMRD. It sounds like all the cotter pins are rattling at once! Any thoughts?
A float question...
I read in the manual how far to lower the mower, so the mower doesn't take all the weight. Huh? How do you know? Any tips on this? Am I just not understanding the manual?
thanks experts... from a complete rookie! /forums/images/graemlins/blush.gif
   / Clickity clack, clickity clack #2
As for the sound ????
The spring clips that hold the 4 pins that hold the mower on to tractor can rub the pulleys so if this is source of sound put pins in so clip is on outside if posible.
To set the mower height drive on a solid level surface (garage floor or apron) and lower mower until the wheels are about 1/4 to 1/2" above floor.
Use this position to set the stop.
This lets the tractor and springs carry most of the weight and still keep mower close to ground.
BTW all the wheels should be set at same spacer height and all should be same distance from floor or the mower needs leveled.
In this case I would call my salesman and have him get someone out to set it up correct.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE LOADER BRACKETS FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE LOADER...
36" Excavators Bucket Attachment (A56857)
36" Excavators...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
