clicking sound
/ clicking sound #1
oakwood
penn.
kubota 7200
i have a B7200 kubota 4 wheel drive. i bought it recently, and thus far love it. when i go from forward to reverse, or reverse to forward, i hear a clicking sound. appears to be coming from the rear axel/wheel area. do the rear wheel attachment thingies periodictly loosen up and need tightening? any imput would be appreciated...oakwood
/ clicking sound #2
Always a good idea to tighten up your rear wheel attachment thingies or lug nuts(wheel nuts) periodically.
They have been known to loosen up.
Welcome to the forum!
/ clicking sound #3
All thingies get loose with age. Best to check them frequently and tighten when necessary. It is commonly known as maintenance....
/ clicking sound #4
Oakwood,
There is a bolt on the back of the hub that tightens a shim to keep the hub tight on the axle. On my B7500, it has to be re-torqued about every 50 hours.
Greg
/ clicking sound
GREG,,,you wouldnt know off hand what the shim/wedge bolt should be torqued to? this form is an astonishing and i might add interesting, manner to get information. my wife thinks im a little sick. she cant believe all we talk about is guy stuff,,,just shakes her head in wonder,,,,,,guess its our testosterone level. oakwood
/ clicking sound #7
Oakwood,
My manual says 91 to 108 ft/lbs. I always give it at least 105. I also periodically remove the wheel and hub from the axle and clean it thoroughly. Sometimes it gets dirty enough that it won't snug down properly. This is a common thing and I have included it in my regular maintenance. If you don't keep it clean and tight, it can actually wear both the hub and the axle.
Hope this helps,
Greg
/ clicking sound #8
I recently was doing some dirt work with a friend's Kubota 2960(?) that has 2 piece rear rims. A slight popping noise began and steadily got worse. The sound seemed to increase/decrease in frequency as speed increased/decreased. I checked the rear lugs and the 4 bolts holding the outer rim to the center section and found them loose. Tightening them stopped the noise. The other rear wheel had been welded where the 4 bolts had been.
/ clicking sound
i torqued the bolts to the designated foot pounds and it did quiet the clicking noise. the weather here in pa. over the weekend was so nice, i took advantage of it. useing my fel i moved about 10 tons of dirt/sand. its my first real experience in useing it and im like a kid in a candy store. like you stated greg i might have to pull and clean them also. this might prove to be fun, since the ties are foam filled.
/ clicking sound #10
Oakwood,
My tires are filled also. It really isn't as bad as you might think. If you carefully jack the rear axle just high enough to take the load off the tire, you can "tip" them off the studs, without having to lift the tire.
Did you find any of your lug nuts or bolts loose? Just want to make sure we aren't misdiagnosing something. A "clicking sound" could mean a lot of different things. The technical term for the sound the loose hub bolts make has also been described on TBN as "eernt, eernt, eernt"...... /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif
Greg
/ clicking sound #11
<font color="red"> "eernt, eernt, eernt"...... </font>
Thats good Greg!!
How about it Oakwood???
/ clicking sound
hambone,,,ok, who let the word out? you guys must have been talking to my relatives or hunting buddies. i take a lot of heat over my hunting calls/sound effects, or lack of. /forums/images/graemlins/smirk.gifits still making a little noise but as i previously stated ill probly take the whole whl. off and clean ,as per gregs recomendation. i live on top of a hill with a large horseshoe driveway. for several yrs maintained the driveways with an old farmall cub. got tired of fighting in the winter to get back up the driveways /forums/images/graemlins/tongue.gif this kabota with4 whl. and chains. my oh my what a pleasure to operate. i even plow going up hill /forums/images/graemlins/grin.gif by the way do any of you know much about the brake design on these tractors, my right side tire has a tendency to want to lock up regardless how easy i apply pressure,,oh ,,,,,i would describe the sound the whls were making as more like a [kalinck,kalinck,kalinck]. now you understand why i get so much ribbing bout my hunting calls. /forums/images/graemlins/smile.gif oakwood
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
2014 F-150 STX (A56438)
2014 F-150 STX...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2008 Ford Expedition SUV (A61574)
2008 Ford...
