Clearing weeds in driveway
   / Clearing weeds in driveway #51
My state DOT recommends Imazapyr for control of weeds along the edge of the road but for some reason retailers do not sell a concentrate and Amazon won't even deliver. When I was out of state last year I ordered a quart so I have that. I'm going to mix glyphosate with imazapyr and spray with a sprayer mounted to my lawn tractor. I usually mix 1.5% (2oz/gal of roundup power max).
Last year I found a somewhat concentrate imazapyr/glyphosate mix at walmart that seemed ok at best. I added that to my glyphosate mix (don't remember the ratio I selected) but didn't like using the backpack so looking forward to the mounted tractor solution.
I think I'll try your mixture on my 600 foot drive. Current method is spray it good with glyphosate mix in the tow-behind sprayer, wait a few weeks to see what's left, then go back and spray anything that's still green with the same stuff in the hand sprayer. As mentioned, doesn't keep new stuff from coming back, but if I can get everything cleaned out once, then there's a chance I can keep up by just occasional spot-spraying and pulling weeds. Unfortunately, this year I let it go much longer than intended, so kind of had to start with a big mess.
I'm using this rig, with an old PCU side panel to block the spray on one side along the driveway edge. I have found this works very well.
Same area 1 week later.
My experience has been that the less disturbance of the gravel, the better. Rearranging the gravel tends to make it wash easier and also seems to make the weeds sprout even faster for me.
   / Clearing weeds in driveway #52
I use RM43 and it keeps everything I spray down for a few months.
Takes a while to work , but it does.
Everything died and hasn't tried to come back. I wanted to get the dead moss out so i hooked the dethatcher up and broke everything up. That may be a mistake but I'll know for the future. Right now it looks amazing!
   / Clearing weeds in driveway #54
Muriatic acid, also known as hydrochloric acid, is sometimes used in well water systems for well rehabilitation to improve water flow. It can dissolve mineral deposits, iron and manganese oxides, and other substances that can clog wells. However, it's a strong acid and requires careful handling and safety precautions.
Used in swimming pools also.
   / Clearing weeds in driveway #55
I read a lot on here about RM43, but I'm a bit confused. RM43 is 41% glyphosphate whereas Roundup is 50%. Is there something about RM43 that makes it more effective?
   / Clearing weeds in driveway #56
It is in a mix that makes it stick around better, not sure how/what.
So instead of working fast in 24 hours, it works slow and lasts months (based on how much rain you get).
Of course this means you have to be very careful not to have it drip or spill anywhere , ask me how I know ....
   / Clearing weeds in driveway #57
I haven't read most threads but the homeplace and this place used to be gravel, now asphalt.
I read many years ago in Farmer's Almanac an old then fellow wrote an article about it and he used an old watering can and filled it with used motor oil, old gas or diesel and went down drive with it which worked for me. (environmentalists would have a hissy fit)
I was helping a 42yo neighbor with his '85 Dodge pickup, I told him the leak he asked be about was coming from the transmission. I said it's probably a 727 Torqueflite and it's the gasket. Let's get a filter kit, pop the pan off and we'll sprinkle old tranny fluid down your gravel driveway killing weeds. New filter, fluid, Permatex, gasket... easy peezy.
I thought he was going to have a stroke!
Never did do it.
   / Clearing weeds in driveway #58
Never did do it.
There are better ways; prime and sand. I saw a video of a guy using a watering can (pretty common on small areas), and he used a leaf blower to get better distribution. Then load your 3pt fertilizer spreader with clean sand, and sand the fresh prime. Small areas, you can shovel sling the sand.
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
*Selling at Royal Auction Zephyrhills, FL Location* (A59231)
*Selling at Royal...
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR7DDBZ7653 (A57453)
2013 Freightliner...
Spatco Air Compressor (A57454)
Spatco Air...
2011 Jacobsen T-700 Reel Mower (A56859)
2011 Jacobsen...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
