Clearing Trees
   / Clearing Trees #11
I have pulled out trees the size you are talking about with my 4X4 truck. It will pull out a 5" tree without giving it gas, just let the clutch out slowly and pull it over. The bigger ones I then pulled form the other direction to break the root on both sides. The secret is to get a long chain (longer than the tree) and a ladder. Climb up the tree as high as you can reach and connect the chain. The higher the more leverage you have and the easer it is to pull over. Also the longer the chain the less weight transfer there is from your back wheels.
Your tractor should be able to out pull a pickup truck and with the long chain the tree can't reach you.
You will be surprised just how easy it is to pull a tree over with 20' of leverage
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
