Clearing snow (3 kilometer long wood trail)
   / Clearing snow (3 kilometer long wood trail) #1
Captm
2022 Kioti DK4210SE
Hello everyone,
This is my first time here, just pulled the trigger on a 2022 Kioti DK4210 this week.
I dont have much experience plowing/pushing/blowing snow, so I was wondering what would be the best attachment that I should get to clear the snow in my 3 Kilometer long wood trail?
I just want to make a path wide enough for the tractor to collect wood.
My tractor does'nt have snow chains yet, but my land is pretty flat so I figured I'll wait and see how much traction I'm able to get in the trails.
Oh and by the way we get a fairly decent amount a snow here in Quebec, Canada
   / Clearing snow (3 kilometer long wood trail) #2
What part of Quebec?
Here are snowfall amounts in Quebec City.
   / Clearing snow (3 kilometer long wood trail) #4
How often do you get 1 foot plus snowfalls?
Not very often, from my perspective, a one foot plus snowfall is a lot. The snow falls we get are more like 3-4 inches maybe 5-6 times a month. And then maybe 2-3 times a year a bigger one that would get closer to the one footer.
   / Clearing snow (3 kilometer long wood trail) #6
I clear snow from my woods trails with a FEL plow. I have a rear blower but it's too slow. With the FEL plow, I don't have a bucket so I carry wood with a 3pt carry all.
   / Clearing snow (3 kilometer long wood trail) #7
Assume you are getting a cab? Most of the time (unless we get 16" in one snowfall) I can clear a path using the FEL 6" off the ground and when it builds up every 100' or so, just push left/right. Do you need to plow/clear your driveway too?
Least cost, build a simple V plow with PT wood and attach to your loader, second find/buy used a SSQA snow plow, are you getting a grapple so you have another set of hyd. lines, then a pull type snowblower - probably the most costly $6K or more.
What about buying a used snowmobile and pack a trail to from your woodlot?
   / Clearing snow (3 kilometer long wood trail) #9
Some of the "old timers" have told me they used to drag a evergreen "top" down the trails to pack it.
I usually get the wood out in log lengths before the snow becomes deep and then work them up later.
You should keep an eye out for some tire chains. 👍
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2021 BOBCAT T595 SKID STEER (A52706)
2021 BOBCAT T595...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A56129)
2019 INTERNATIONAL...
