Clearing Recently Purchased Land
   / Clearing Recently Purchased Land #1
walker450
Platinum Member
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
A few weeks ago, my wife and I bought 6.5 acres that we are going to build a home on. I'll post pics and videos on this thread.
I borrowed my father-in-laws Ford Utility tractor and brush hog to perform the initial clearing of small trees. I was able to take most small trees out with roots and all just by using the front-en-loader. I used my Kubota BX2350 to stack all of the brush. I then cut several dozen cedar trees with my Stihl 039 chainsaw. I will stack those tomorrow evening.
Here is a time-lapse video of me cutting cedars:
   / Clearing Recently Purchased Land #2
Whats next???
   / Clearing Recently Purchased Land #3
I hope you got the stumps flush with the ground when you cut the trees. Some of the worst damage I've had to equipment was when the bush hog front edge caught the top of a stump. The cutter flipped up vertical and bent the front edge of the cutter enough so that the blade hit it. When the cutter came crashing back down, it broke the deck where the tail wheel brace is located.
I will be stacking small cedars to burn. The larger ones will be saved for fence posts.
Wow that's a wild experience Ken! I cut them as low as possible without running the chain in the dirt.
The stumps are all less than 2" tall. I may grind them out or just leave them for a while. We won't be building for a few years. I just need to be able to brush hog a couple times per season.
   / Clearing Recently Purchased Land #6
I like your video, isn't that about the same way Superman does his yard work?
lol yeah that video sure makes it look easy!
Here is a pic I took when I got done:
   / Clearing Recently Purchased Land #8
You sure did a lot of work, really liked all the pictures.
Love that old Ford, built like a tank.
   / Clearing Recently Purchased Land #9
Great job and especially like the sunset.
Thanks everyone!
Here is what I done this afternoon:
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
