Clearing cedar trees with pallet forks
   / Clearing cedar trees with pallet forks #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
I am clearing some fields of the cedar trees to get ready for plowing this spring. I had the pallet forks on so decided instead of messing with the grapple and bucket I would use the forks. The ground is very wet but made me worry less about all the multiflura rose I was driving on.
   / Clearing cedar trees with pallet forks #2
So you just cut them down? What about the stumps? When you plow or when you mow the field? Those stumps are like little land mines just wanting to reach up and rip off your hydro filters.
I cut them level to the ground. The big problem will be when the plow hits the stumps but it's a large auto reset plow that will trip and hopefully over time they will rot or be pulled out.
   / Clearing cedar trees with pallet forks #4
Those Cedars look to be less than 6 inches in diameter at the base. Couldn't you have pushed them over and popped the stump out before cutting them up?
Popping them out just didn't work on the cedars. Not sure if it's my ground or the root systems, did work on some in another field but got frustrated and started cutting them.
Your last picture Island is a beaut., with that sparking blue water in the background.
   / Clearing cedar trees with pallet forks #6
I like the tractor sunset photos the best. It means I'm not far from a cold beer.;)
That's one Kioti should use in an advertisement but maybe everyone would be looking at that unbelievable sunset instead of the tractor!!
   / Clearing cedar trees with pallet forks #8
There is a reason folks use cedar for fence posts and pickets. They don't rot for 15-20 years...or more!! :(
More work but nice to not have to run over stumps. Even little ones.
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
Horizontal Hydraulic Wheel Press (A59213)
Horizontal...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
PALLET OF MISC (A58374)
PALLET OF MISC...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
