Clearing 154 acres of woods in west Tennessee
   / Clearing 154 acres of woods in west Tennessee #41
In Md., you would be 100% wrong. Ponds are to contain water, you’re supposed to pipe it out to watering troughs, etc for use. The natural resources conservation is coming out Tuesday to check our pond fences and take pictures of it.
The USDA guidelines under water quality suggest fencing out livestock, Md is saying you will do it. Hence the suggestion to check before you start.
Another example of government overreach if true.
Last I saw they suggest it in MD, but haven’t seen that it is required. I believe they only check if you took money from govt to pay for the fencing. They have programs to help pay for it.
   / Clearing 154 acres of woods in west Tennessee #42
I would recommend talking to someone who would potentially buy the lumber first. Barring that, I would say a 20 ton + excavator with a thumb (mechanical is fine) would be a good starting place. It's much easier to get the stump out if you do it with the tree attached. You can push the tree over with the Ex and stack it with the thumb to either use later or burn. Always PUSH and always AWAY never pull toward the machine. You may have to dig around the close side to cut a few roots on the larger ones. Huge trees may be a problem this way, but most should be fine.
I would think a good operator could potentially get an acre cleared per day and burn a little less than 60 gal of diesel doing it that way. That's a spitball guess but I wouldn't think it would be faster than that unless there were not many trees.
Then you would probably want to run over all that with a dozer to smooth it.
If you cut the trees first, I've seen a track loader do a good job pulling stumps. Not a compact but a big dozer style metal tracked one, not sure how large would be needed but I assume something 10 ton + I don't even know if 10 ton would do it.
   / Clearing 154 acres of woods in west Tennessee #43
Forest fire? :geek:
Seriously, could you sell your trees and have it cleared that way?
   / Clearing 154 acres of woods in west Tennessee #44
   / Clearing 154 acres of woods in west Tennessee #45
Outsourcing is the fastest/cheaper option.
I would rephrase that to, get some quotes from quality contractors. If this is 1 acre per 8 hr day kind of woods; that's going to be around $400k +. I Might look at an older JD 200 hoe, for around $120-150k, and do that. Just know going into it, you probably want to budget $50k for repairs, maintenance, ect. I dont think I would look at the $30-50k machines, they are probably worn slap out.
   / Clearing 154 acres of woods in west Tennessee #46
I would rephrase that to, get some quotes from quality contractors. If this is 1 acre per 8 hr day kind of woods; that's going to be around $400k +. I Might look at an older JD 200 hoe, for around $120-150k, and do that. Just know going into it, you probably want to budget $50k for repairs, maintenance, ect. I dont think I would look at the $30-50k machines, they are probably worn slap out.View attachment 807939View attachment 807941
In hindsight, the fastest is never the cheapest usually.
Around here operators typically work by the hour instead of a big job. So if you got started you can find out what the cost would be and everything pick you a spot that you wanted to go with first perhaps.
   / Clearing 154 acres of woods in west Tennessee #47
Yeah, if you have the machine you can probably find someone good for $25/hr pretty easily.
   / Clearing 154 acres of woods in west Tennessee #49
I'd consult a forester. I see a lot of hardwood, white oak maybe, around west Tennessee going for staves, pallets and, maybe, ties. When we cut timber in north Mississippi, hardwood pulp was higher than pine pulp. I think it's highly location dependent.
Yes, but we have paper Mills in the south and osb plants, mdf plants even. I'm just across the river.
   / Clearing 154 acres of woods in west Tennessee #50
When we clear, we use a big ole junky trackhoe and two skid steers. We have a D 7 but don't use it. Knock trees down, saw stumps off. Then we have a big square hole dug. Throw them stumps in the hole and light er up. Keep the inferno going. Firewood all that hardwood from the trees. Get the limbs with the skid steer grapple. If you're worried about food, firewood should be a concern also.
2022 Chevrolet Silverado Pickup Truck, VIN # 1GCUDEED6NZ533617 (A57453)
2022 Chevrolet...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
New/Unused Electric Golf Cart (A57453)
New/Unused...
