Clearance issue ice chains and 3 point arms
/ Clearance issue ice chains and 3 point arms #1
Boomer Mark
Bear River, Nova Scotia
New Holland Boomer T15110
I have a used NH T1510 Boomer,,, and I bought ice chains for this rig. I have the chains mounted properly but they are less than an inch away from the lower 3 point hitch arms when using my back blade. Is there different arms to purchase that run out straight from under the pins on tractor and at the attachment end they then curve respectively to mount at the hitch pin?
I thought of reversing the hitch pins on the back blade so they pointed inside but there is a welded support there that won't allow me to mount the hitch arms.
Any suggestions?
Mark
/ Clearance issue ice chains and 3 point arms #2
I'm open for suggestion as well. I have the exact same tractor with the exact same problem. Wayne
/ Clearance issue ice chains and 3 point arms #3
Post a pic or two- easier to see what you are dealing with.
