Cleaning up the "Back 40"
   / Cleaning up the "Back 40" #1
jwasbury
Bucks Co., PA / Hudson Co., NJ
JD 420, Kubota B2320
I recently acquired a Kubota B2320 with a FEL and BH. In just a few weeks, this little machine has proven its usefulness around my 13.5 acre property in Bucks County, PA. One of my primary "excuses" for buying the tractor (and I don't need much of an excuse to buy tools) is that I want to clean up an abandoned pasture on my land, put in and maintain some trails, and improve the access to a pond that is tucked away on the back part of the old pasture. The ground water in my area is very high, and the old pasture is pretty wet. I've noted there are old trenches around the perimeter of the pasture area, along with a few swales across the center. These have not been maintained for probably 20 years or more. Speaking with my neighbor (who actually grew up in the house I own), He tells me there used to be a "good flow" through the property, and they kept horses in the pasture...this is dating back to the 1980s.
So, my mission is to clean up the old pasture which will require restoring the drainage trenches to get the land to dry out a bit. Eventually, I want to be able to hike over to our pond without putting on mud boots.
Here is the old entrance gate to the pasture area. There are two distinct trails which perhaps the prior owner had cut. I suspect that he had similar intentions to restore the area, but never got to it
This photo gives a sense of the existing trail. This one ends up at the pond. It gets very wet about halfway to the pond.
This is the place where it is most wet. The land it fairly flat, and with all the vegetation, it's difficult to assess subtle elevations in the land. This specific place has stayed pretty wet, despite the fact that it's been dry and hot over the last few weeks. When we had rain a few weeks back, I could see this is where much of the water naturally flows to, but it seems to lose some direction at this point and spreads out and pools here. I drove the tractor to this point and started spinning wheels. Back up and started a trench with the back hoe. This trench will bisect the pasture area. I can see where the water would flow to if this little stream bed weren't so silted up. I also found boards here as I dug with the backhoe. Prior owner probably put them there to drive some machinery across and they were left here, and then got covered with mud and grass...probably contributed to plugging up the works too.
The pond...also needs a bunch of work
The pasture is loaded with these dead scrub trees. It looks like they grew up ok, but then as the drainage trenches silted up, much of the pasture got too wet, and drowned these out. I'm cutting these down and skidding them out to a burn pile.
This is going to take a while, with me chipping away at it bit by bit, but I am enjoying the journey so far.
   / Cleaning up the "Back 40" #2
Very nice write up!
Looks like a lot of work, but I'm sure it will all be worth it. I hope you'll keep posting your progress along the way. It would be fun to watch!
   / Cleaning up the "Back 40" #3
I can see you will utilize the Backhoe plenty.
   / Cleaning up the "Back 40" #5
I'm doing exactly the same thing, except I don't have the backhoe yet!!
Look forward to seeing your pictures and progress. Keep up the good work....
Hey! Thanks everyone. I will update with progress and photos. I'm a big fan of these internet forums, and participate in a few that are related to other hobbies of mine. Its a great resource, and I hope to contribute some useful info, as well as entertainment. I also expect to learn some things from people who have "been there done that."
I am painfully aware that forums love photos - here's a few more
This shot taken from just across the drainage trench I started (shown in an earlier photo). This is in the direction of the pond. In the center of this photo, where the trail seems to "end" there are a couple of cedar trees. These are probably 10-15 feet from the edge of the pond.
The B2320 at work. Removed a bunch of the dead scrub trees from this area last weekend.
   / Cleaning up the "Back 40" #7
For all the work you're going to be doing with the backhoe, I'll bet you'd love having a hydraulic thumb on it!
   / Cleaning up the "Back 40" #8
You have a project there. Maybe enlarging the area of the pond would capture some of the drainage crossing the pasture. You could make an island in the middle to reduce the amount of material to excavate.
You may want to check your backhoe manual. They usually say to not pull heavy stuff chained to the bucket as it looks like you are doing in the pic. I have done it and I do think it is hard on the cylinders for some reason. Hard to say how heavy is too heavy. :)
   / Cleaning up the "Back 40" #9
Great pictures. Thank you for posting them. It looks like a beautiful piece of land.
   / Cleaning up the "Back 40" #10
I have enjoyed this so far. Please keep updating as you progress.
2024 John Deere 872GP Articulated Motor Grader With GPS Package (A52143)
2024 John Deere...
John Deere 6175M (A50120)
John Deere 6175M...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
Hunter TCX50 Tire Changer (A50121)
Hunter TCX50 Tire...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A50324)
2004 Fleetwood...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
