Cleaning underside of mmm deck
   / Cleaning underside of mmm deck #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
Has anyone found a way to clean the underside of a mmm deck without removing from the CUT, without lying on your back and reaching under with some sort of scraper, and without eating and/or breathing the accumulated grass that you remove?
   / Cleaning underside of mmm deck #2
I bought a street elbow and put it on the end of the spray wand from my pressure washer, then screwed the tip holder onto that. Worked so well that I went back and bought a separate tube and tip holder so I would not have to have a pipe wrench around to go from angled spray to straight spray. If you try this be careful, and don't squeeze the trigger until the wand is flat on the ground. Just work it back and forth under the deck and try to avoid spraying directly in the center of the blades, where there might be bearings or seals that could be damaged.
   / Cleaning underside of mmm deck #3
I like Bird's idea and leads me to thinking of building a wash bay where the excess water and grass can run off into the woods. Then just hook to a stationary pair of nozzles and stand back.
However, I keep my deck clean with a combination of mowing dry grass, a few hundred sticks that blow out of the trees into my lawn, and some hickory nut husks that rattle around in there for most of the summer from a couple dozen or more shagbark hickory trees. The deck for the most part stays pretty shiny. On the occasion that I change blades and run the tractor up on a ramp, I will take a wonderbar and knock down the dried stuff that sticks in the corners. But seldom get a full shovel of debris. Otherwise, I usually just clean down the mower deck and tractor with air after each use. Try not to use much water. Just my way, for what it's worth. /forums/images/graemlins/wink.gif
   / Cleaning underside of mmm deck #4
I find the long version of my air blower works pretty well, even if the grass is fairly wet......
   / Cleaning underside of mmm deck #5
</font><font color="blue" class="small">( long version of my air blower )</font>
That's what I use, also.
   / Cleaning underside of mmm deck #6
I took a length of 3/4" PVC two feet longer than my 60" MMM. Put a cap on one end and a hose fitting on the other then drilled 1/8" holes. every six inches except in the one foot overhangs. When I am done mowing, I put the pipe under the MMM, turn on the hose and engage the mower...I drive back and forth a bit and the mower is clean. The overhang precludes the blades sucking up the pipe. It worked so well that I assembled another shorter one for my lawn tractor's 38" mower deck.
Bill
   / Cleaning underside of mmm deck #7
What a nifty idea, Bill.
I remember one of my father's riding mowers (Wheel Horse maybe?) having a spot to screw a hose to the top of the deck for the same style of cleaning with water and the blades turning.
   / Cleaning underside of mmm deck #8
I was taught that it is bad to frequently wash your mower deck because warm bearings can draw in water past the seals as they cool. Thus, premature bearing/spindle failure.
Any truth to this?
   / Cleaning underside of mmm deck #9
I was surprised by a similar warning in the manual on a new Cub. They really cautioned about cleaning with water. They even caution you about washing the exterior. I've been power washing my decks for years with no bearing problems?
On the smaller Cubs, it was easy enought to just remove the deck and use a putty knife to clean the underside. On my 1872 with a 60 inch deck, it's just too heavy too manipulate without a hoist so I really try to avoid cutting wet grass, but sometimes, that's your only option.
I bought a 880 lb electric winch and a 3/4 drive socket set from Harbor Freight, the ratchet is about 18 inches and the breaker bar that came with it is even longer. Between that and the winch the cleaning/blade changes got a whole lot easier. The winch was on sale for $79 and the 3/4 socket set was $39. Not MAC or even Craftsman quality but well worth the price for limited use.
Curt
   / Cleaning underside of mmm deck #10
I bought a new Cub AGS2130 in '95 and one of the spindles seized while it was still under warranty. They replaced it under warranty all right, but told me not to wash the deck with water, OR if I washed it with water to run it long enough to thoroughly dry it out afterwards. Now my current Toro ZTR has the coupling on top of the deck to attach a garden hose and run it to wash the bottom side of the deck and I've done that, but instead I usually just use the air hose.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
Forest River Rockwood Freedom Popup Travel Trailer (A51694)
Forest River...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
Year: 2004 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 65,570 Plate: Body Type: 2 (A53422)
Year: 2004 Make...
