Cleaning Under Zero-Turn Deck After Every Session: Really Necessary?
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #101
Somebody teach me the right way.... I have the same mower and use the crank the same way he did. I'M MAKING A FOOL OUT OF MYSELF AND I CAN'T HELP IT!!!
My wife is apparently aware of me making a fool of my self and not knowing it... but I'm not sure the mower is the reason for that...
Once you unfold the handle, make sure you push it in. That keeps the handle from articulating at that joint.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #102
When you fold the orange crank handle out : push it strait in onto the square shaft to crank it smooth & easily.
IF it won’t push in OVER the square shaft : loosen the lock nut on the bolt & possible lubricate it so it’ll easily slide strait in about 3/4 of an inch.
Also Keep the exposed threads well lubed too as dust & clippings stick to it while mowing.
I found the answer to the dirt problem, and it's really easy. Kubota was extremely stupid to leave the left end of the jack assembly open so it lets dirt in.
Disassembling the jack is not hard as long as it's not seized up with dirt and rust. Once you have it apart, clean the tube and the screw carefully, and make sure the bearing is okay. Then put good grease all over the screw.
This still leaves you open to dirt, so you need to fire an enormous glob of sealant into the left (not threaded) end of the tube, sealing it off completely. When the silicone cures, put the jack together and reinstall it.
This seals crud out. It can still get on the screw when the deck is raised, but you're not going to have a lot of dirt in the air while the deck is up.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #104
Oh but some here say they don't bother cleaning the deck LOL
I don't know whether I will clean under my deck or not. It seems like the type of grass I have just falls off. I never saw an accumulation under the deck of my JD. Just bare rust!
This area has really bad grass.
The dirt is mostly sand, so it doesn't stick.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #106
Some people never understand that point Plowboy!
I have noticed that the zero-turn accumulates way more crud than a tractor. There is ancient stuff stuck under the fenders and so on. But the underside of the deck doesn't seem to have this problem.
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2018 Ford F-550 4x4 Altec Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
