Cleaning Under Zero-Turn Deck After Every Session: Really Necessary?
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #91
I figure the deck will last long enough. It ain’t like nothing else is going to fail. I never have cleaned mine
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #92
The original post asks, is it necessary?
Short answer, yes.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #93
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #94
Actually the short answer really is…..
Maybe, maybe not!
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #95
I clean my deck at the end of the season by using it to pick up leaves (and acorns, small sticks, etc) with my cyclone rake. That leaves the bottom of the deck completely clean except for a couple of spots I scrape off. After 15 years there is no noticeable damage to the deck surface. Of course, it's a fabricated heavy deck and not stamped steel. It has a cleanout hose port but I've never used it.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #97
I'm more talking about cut quality.
Nice video but I don’t think he knows the proper way to operate the crank to raise and lower the deck, on my zd21 that slot in the crank handle locks it in position making things much easier.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #98
So you don't even clean it when you sharpen the blades? I may have OCD that makes it difficult to leave all of that sh@#$t there when removing the blades. It's not that hard to do.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #99
Yea , the guy should have at least learned how to use it before making a fool out of himself.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #100
Somebody teach me the right way.... I have the same mower and use the crank the same way he did. I'M MAKING A FOOL OUT OF MYSELF AND I CAN'T HELP IT!!!
My wife is apparently aware of me making a fool of my self and not knowing it... but I'm not sure the mower is the reason for that...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
