Cleaning Under Zero-Turn Deck After Every Session: Really Necessary?
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #81
I’m a one man band mowing 20 acres here on the farm weekly.
Occasionally when the stars align just right : I can persuade my wife into mowing with the backup ZD1611 mower :love:
Two 72” 4cyl Turbo Zero’s can flat cover some ground :LOL:
Wow thats too much mowing.
If it was me it would be hay to the highest harvester.
And maybe mow a few.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #82
I've read all these posts and it must be geography.
Ain't no way I could wait till the grass is dry to mow, it would be 10" tall and certain areas the grass is always damp, or not clean it every time. Next week it would be concrete under there and the cut would be terrible. Not just this mower deck, every one I've had.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #83
Exactly.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #84
I use to let the in-laws cut it for hay BUT HUNDREDS of Gopher Rats took over my home, barns, sheds, vehicles & poultry houses.
So I bush hog 7acres with 15ft batwing & zero 20 acres.
Hawks & coyotes will eat what few shows up.
Rat problem solved.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #85
Rat problem solved.
Still 20 acres is a lot for a zero turn. I've never seen anyone here in East Texas mow more than a few acres with one. All tractor stuff over a few acres.
I only mow about 3-1/2 acres. Takes a couple hours and 5 gallons of gas. Hoping this new ZD1611 helps.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #86
I mow 7+ acres in northern Indiana every week with my Lazer Z, and have for 25+ years, used a 20 HP Wheel Horse, before that for 12 years
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #87
I used a 6ft then a 7ft then a 9ft rear finishing mower behind a 66hp JD tractor for 20yrs
The 4cyl Turbo Diesel 72” ZD Kubota mows WAY SLICKER & I can trim better BUT it doesn’t save me any time at all.
I miss the smooth ride of tractor with all 4 tires fluid filled.
iF Exmark 96” Zero was a side discharge deck : I’d try one but the rear discharge Kubota left windrows BAD in thick heavy grass.
It cut great but left windrows were horrible.
I tired numerous blades & removed baffles, guards
Nothing helped
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #88
Those eXmarks are good machines but hell on the kidneys. I had a Lazer X EFI. Sold it after the first season and bought a Ferris. What a difference in ride quality. That was two years ago. The other day I got the Kubota ZD1611.
Selling the Ferris. The air ride seat on the Kubota does the job. I love the built in jack that uses the whole front axle to raise the machine. Went from 61" cut to 72".
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #89
To clean the underside of the deck, many now come with a water hose connection on the deck. An aftermarket hose connection kit is also available.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #90
Those things are generally only found on stamped deck, low budget machines and are not very effective.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2025 MACK GR64F DUMP TRUCK (A59823)
2025 MACK GR64F...
