Cleaning Under Zero-Turn Deck After Every Session: Really Necessary?
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #1
Suburban Plowboy
FL
Kubota L3710
I am still struggling to find a used diesel zero-turn to replace my aging JD 430. I wanted a Kubota ZD because they have built-in jacks, but good ones don't pop up often at realistic prices. Right now, I can get an okay deal ($8900 asking) on a Gravely Pro Turn 460 with a Kubota engine. A younger ZD326 that looks good has materialized at a better price, but the seller can't show it to me until Friday, and in situations like this, a pushy buyer usually shoves his way in and beats me to the deal.
The Gravely looks good, but I have two issues with it. First, the spindle bearings are sealed, so sooner or later, I will have to replace them. Kubotas have zerks, so I expect the spindle bearings to last longer. Second, the Gravely has no jack, so if I want to get under the deck, I have to drag out a floor jack, a two-by-four, and jackstands.
I have been told that if I want a deck to last, I have to raise it and clean it every time I use it. Is that realistic advice? If it is, I really need a Kubota, because there is no way I'm going to drag a bunch of junk out of the shop every Saturday so I can clean under the Gravely's deck.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #2
Have a 2005 Cub Cadet Z-Force. Deck gets cleaned when I change blades and if I have to mow wet grass. Change blades 1 or 2 times during mowing season, try not to mow wet but sometimes not avoidable. Maybe clean deck 2-3 times during mowing season, certainly not after every mowing. Deck 20years old and still going
Thanks. How are you cleaning the deck? Seems like a hose would just encourage rust. I have blowers and a big compressor.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #4
I have a chain that I pick up front end with loader and then put a jack stand under deck and let it pivot on rear wheels while leaving tractor chained to mower. Gives me ample room to get impact on spindle nuts to swap blades and give deck a good scrapping. Use an old butcher knife from years ago and putty knife
Geez. Knives? You must have some serious crud up there in Tennessee. I have never noticed much of anything stuck to my deck here in sizzling Northern Florida.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #6
Unless the deck is stamped steel sheet no cleaning is required, I only clean mine when I get time, which is normally 2X yr.
My Hustler deck is welded together 1/4" sheet steel W/steel strap bracing around the edge of the deck. I bought that Hustler in 2002, it still has the original sealed spindles. My yard is 1.5A plus I mow the roadsides in front of my property and inside my fence lines at least 1X Wk.
The caveat is, it's always stored in my garage and never wet unless I wash the machine, then I blow-dry it with a leaf blower.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #7
Just something I use as sometimes it is thick in places on occasions. I currently use Oregon gator blades and they have a little more lift than OEM blades. If you mow before 1pm here more than likely your tire will get wet, so much humidity in air this time of year. Would think in Florida it would be very humid also which tends to make grass stick to deck when wet.
I would expect real grass to stick to my deck a lot more, but this stuff is like whatever the devil has in his yard in hell. Long, stringy, tough grass that looks great from 100 yards but is actually extremely thin up close.
   / Cleaning Under Zero-Turn Deck After Every Session: Really Necessary? #10
I wouldn't worry too much about the sealed bearings or the missing jack. Gravely mowers are big here with commercial guys and they wouldn't run them if the spindles were failing with any frequency. I have always heard that commercial mowers are generally good for around 1,000 hours before anything of any expense needs addressed, other than fluids, blades, and belts. If you are not having trouble with wet grass getting caked on currently then you won't have any need in getting under the deck more often than your preferred blade maintenance interval. I have very seldom used a floor jack during blade maintenance. I usually either pull part way up on a trailer if one happens to be handy, oil change ramps, or a chain on my front end loader. I do have a ZD1211 with the built in jack now, which is nice, but it has not been any type of game changer for me.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
iDrive TDS-2010H...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
